I have read lots of posts regarding header installs and ensuring the engine is centered and located properly. I noticed many small areas that can contribute to some grief and anguish that will have the dimensions out and will be checking as much as possible when I set the motor down and lock it in. I have found most all dimensions I think I will need but one. When I was cleaning up the kmember it looked like the mounting holes that the mm bolt sticks through was wallowed out I assumed from a loose mount. I cleaned it up some by welding it back until it was symmetrical, now Im curious what it should be. So what I am looking for is the length of the slot that the mm bolt will go through on the kmember, width is known. Dimension from top of hole to bottom is what is needed. Just thought I would check before running into issues.
