[SOLD] Mopar A Body 4 speed 1969 casting date
jtkaaa07
BossMan
Neenah Wisconsin
Brand new fresh rebuild, 23 spline input, 30 spline output standard gear. This is not an OD! Build date on the one is December 2nd 1968. 2:66 low gear, which is standard for 69. New cluster gear shaft, new non leaking reverse switch, new bearing retainer. Case was completely disassembled bead blasted, threads chased, all new bearings and seals as well as new keys and springs and brass on synchros. Ready to install just add gear lube! Asking $1100 plus ride, Located in central Wisconsin. This is a great deal on a like new transmission! Shipping normally runs around $150-200 depending where your located in the lower 48. For any members in the area, I do offer a rebuilding service.
Jeff
