MoPar Brake Upgrade Options?
Brakes for your Classic Mopar
IF this package existed, would anyone be interested in it?
  1. YES!
    4 vote(s)
    33.3%
  2. Maybe... How much?
    7 vote(s)
    58.3%
  3. Nope
    0 vote(s)
    0.0%
  4. This already exists you bonehead!
    1 vote(s)
    8.3%
  1. AndyF
    AndyF Well-Known Member
    1,201
    798
    Feb 23, 2009
    Oregon
    Local Time:
    6:22 AM
    If you pick up a copy of my B body book (available on Amazon) you'll find a bunch of custom brake stuff. I think I did about 3 chapters worth of brake stuff in that book. Almost all of it applies to A body cars since most of the front end stuff interchanges between A, B and E body cars.
    • Thanks! Thanks! x 1
    • JoesEdge
      JoesEdge Well-Known Member
      991
      187
      Jun 6, 2013
      Downey, CA
      Local Time:
      6:22 AM
      Ok cool. I'll look for that book and I'll put FMJ cars on my wrecking yard watch list for the spindles, but everytime I find a '73 up Mopar with disc brakes, it seems that's always the first to get salvaged.
    • Dustert73
      Dustert73 Stripping bolts since ‘10
      756
      54
      Dec 22, 2014
      Ohio
      Local Time:
      9:22 AM
      Hey man, any more updates?
    • cuda guy
      cuda guy Well-Known Member
      351
      17
      Oct 15, 2009
      Local Time:
      8:22 AM
      What would be the best Willwood master cylinder to use on a 1968 cuda with front disks and drum rears
    • D_Matheson
      D_Matheson Matheson Sports Car
      18
      13
      Feb 13, 2018
      Jonesborough, TN
      Local Time:
      9:22 AM
      I reached out for quotes on the hubs. But, by the time you buy the calipers, rotors, and then have the hubs and caliper adapters machined, it would actually be cheaper to buy a nice radial mount Wilwood caliper, make a radial mount adapter, then use the stock hub/rotor. I think the kit I designed would work well! I just think I can get equal stopping power for less going the Wilwood route.
      The machining costs were so high because I was only ordering enough for one kit. I think I could get reasonable quotes on the machining if I was doing a larger production run, but so few seemed interested in it that it would be a big risk for me. Not worth it at this time. For now, I might just keep moving with the Rally Cuda project without a major front brake upgrade and circle back to this later.
    • 69_340_GTS
      69_340_GTS Well-Known Member
      3,116
      1079
      Jul 11, 2014
      Torrington, CT
      Local Time:
      9:22 AM
      Not power brakes? Wilwood #260-13375 (15/16" bore). They are nice, but I really dislike the way they use 4 very tiny (and leaky) screws to hold the cover on. Don't forget, you'll need the 2-bolt to 4-bolt adapter plate, and also an adjustable pushrod.
    • cuda guy
      351
      17
      Oct 15, 2009
      Local Time:
      8:22 AM
      What in your opinion is the best non power master cylinder to use for a 1968 440 cuda disc and drum combo with firewall headers
    • JoesEdge
      991
      187
      Jun 6, 2013
      Downey, CA
      Local Time:
      6:22 AM
      This works very well: Mopar Aluminum Master Cylinder Kit
      Go with the 15/16" bore for less pedal effort.
      I'm using the 1 1/32" bore but I can tell you it does require a bit of pedal effort. Not a big deal to me, because I have strong legs.
    • Dustert73
      756
      54
      Dec 22, 2014
      Ohio
      Local Time:
      9:22 AM
      Sorry to hear that!
