Mopar electronic ignition wiring schematic question
Electrical and Ignition
  1. prorac1
    prorac1 Well-Known Member
    1,510
    1371
    Sep 29, 2012
    Martin, Mi
    Local Time:
    8:56 AM
    The above picture is what we are using for electronic ignition, and dual field alternator and regulator conversion . Two post ballast resistor, and four pin ECU.
    My question is, there are three unlabeled wires that go off towards the right-hand side of the schematic.
    One of them, obviously is the main charge wire for the alternator.
    What are the other two?
    The original wires for the point style ballast resistor?
    Thank you in advance for the help. Eric and Jason.
  2. 4spdragtop
    4spdragtop CONGRATS NORTH AMERICA! FABO Gold Member
    31,508
    11996
    Aug 28, 2009
    Wasting time here
    Local Time:
    7:56 AM
    Believe ballast goes to key switch.
    • Thanks! Thanks! x 1
    • Agree Agree x 1
    • prorac1
      1,510
      1371
      Sep 29, 2012
      Martin, Mi
      Local Time:
      8:56 AM
      I believe your right. I believe that's what those wires are.
      A keyed hot and a crank hot.
      Original ballast wires.
      But I'm not sure if they are polarity sensitive, or if they are even ignition switch wires honestly.
      Assuming gets me in trouble. Lol.
      • Like Like x 1
      • 4spdragtop
        31,508
        11996
        Aug 28, 2009
        Wasting time here
        Local Time:
        7:56 AM
        Yep I just put my pos away for winter storage. Electrical issues fd my entire summer up. Sorry I ain't much help lol. Good luck.
        • Like Like x 1
        • prorac1
          1,510
          1371
          Sep 29, 2012
          Martin, Mi
          Local Time:
          8:56 AM
          Thank you for trying though. LOL.
          That's why were over analyzing every circuit on this wiring harness. To avoid having those problems in the future. It's all laid on the bench in front of us, if we're going to do it, we may as well do it now and right.
          • Agree Agree x 1
          • Mike69cuda
            Mike69cuda 66 is the new 17 FABO Gold Member
            2,273
            1795
            Jan 2, 2018
            Overland Park Kansas
            Local Time:
            7:56 AM
            I don’t understand the diagram. Why is the voltage regulator hooked to the start ignition supply? Seems wrong to me. Seems like the blue voltage regulator wire should be on the other side of the ballast resistor.
            • Mike69cuda
              2,273
              1795
              Jan 2, 2018
              Local Time:
              7:56 AM
              Top wire appears to be “start”
              Middle wire appears to be “run”
              Bottom wire appears to be “battery”
              • pishta
                pishta I know I'm right....
                19,830
                9200
                Oct 13, 2004
                Tustin, CA
                Local Time:
                5:56 AM
                • prorac1
                  1,510
                  1371
                  Sep 29, 2012
                  Martin, Mi
                  Local Time:
                  8:56 AM
                  I have that diagram also. But I'm not sure how it would translate to a two post ballast resistor.
                  We have the four pin ECU, so I figured I would use the original looking to post ballast resistor.
                • prorac1
                  1,510
                  1371
                  Sep 29, 2012
                  Martin, Mi
                  Local Time:
                  8:56 AM
                  Beats me. But that's how all of the diagrams I'm finding are wired.
                • prorac1
                  1,510
                  1371
                  Sep 29, 2012
                  Martin, Mi
                  Local Time:
                  8:56 AM
                  I found this Schematic from Mopar performance. It seems more along the lines of the one shown above only with a two post ballast resistor
                • 4spdragtop
                  31,508
                  11996
                  Aug 28, 2009
                  Wasting time here
                  Local Time:
                  7:56 AM
                  Heres how I did mine, handdrawn diagram.
                  • 67Dart273
                    67Dart273 FABO Gold Member FABO Gold Member
                    48,278
                    16312
                    Oct 14, 2010
                    Idaho
                    Local Time:
                    5:56 AM
                    That diagram is wrong. The coil/ ballast wiring, whether 4 or 2 wire is unchanged from points. That is, the coil part of the wiring is all the same.
                    • prorac1
                      1,510
                      1371
                      Sep 29, 2012
                      Martin, Mi
                      Local Time:
                      8:56 AM
                      So the ballast is wired backwards in the original pic I posted?
                      Should I use Pishtas diagram than?
                      Thanks. Eric
                    • 67Dart273
                      48,278
                      16312
                      Oct 14, 2010
                      Idaho
                      Local Time:
                      5:56 AM
                      https://www.forabodiesonly.com/mopar/attachments/img_4787-png.1715251248/[/mg]
                      This is also partially wrong because of the reference to the yellow colored wire to the start relay. That wire is also unchanged in reality. It is supposed to be the coil/ bypass circuit IE ign2, which goes from the coil+ side of the ballast to the ignition switch IGN2 contact. it supplies power to the coil/ ignition for starting and bypasses the ballast
                      If you are ADDING a 4 pin ECU / breakerless system here are the basics Numbers are simply enumerators not pin numbers
                      A...GROUND ECU box MUST be grounded. MUST
                      B&C..........distributor pickup
                      D...............power to ECU. This goes to the "high" side of the ballst, IE directly from the key IGN1. This point also branches off under the hood and supples alternator field (blue), VR IGN terminal (blue) electric choke if used, and sometimes smog devices
                      E...........Coil NEG........this wire goes to coil - and switches the coil on/off just like the points did
                      • prorac1
                        1,510
                        1371
                        Sep 29, 2012
                        Martin, Mi
                        Local Time:
                        8:56 AM
                        That's beautiful!
                        That will work perfect!
                        Thank you very much sir.
                        • 67Dart273
                          48,278
                          16312
                          Oct 14, 2010
                          Idaho
                          Local Time:
                          5:56 AM
                          This is from MyMOpar. It is correct except it does not show the bypass (IGN2) circuit which is unchanged, anyhow. Notice at top right it says "splice" and "new wire". This is spliced into the existing ballast power supply wire from the key. So basically you leave the ballast / coil alone, disconnect the points, and hook the wire from the ECU up to the coil NEG in it's place
                          • 67Dart273
                            48,278
                            16312
                            Oct 14, 2010
                            Idaho
                            Local Time:
                            5:56 AM
                            Sorry guys but some of the diagrams posted here are too darn small for me to read
                            • Like Like x 1
                            • prorac1
                              1,510
                              1371
                              Sep 29, 2012
                              Martin, Mi
                              Local Time:
                              8:56 AM
                              Thank you so much. That definitely cleared a lot of things up.
                              I think I was over thinking it.
                              Leave ballast wires alone (stock)
                              Tie dual field alternator/regulator in with 12 volt feed to ECU.
                            • prorac1
                              1,510
                              1371
                              Sep 29, 2012
                              Martin, Mi
                              Local Time:
                              8:56 AM
                              Our biggest stumbling block is that we are starting with an empty shell.
                              So I had no previous hook ups to reference from.
                              • Like Like x 1
                              • prorac1
                                1,510
                                1371
                                Sep 29, 2012
                                Martin, Mi
                                Local Time:
                                8:56 AM
                                Maybe a silly question.
                                But (just in case, I'd better ask) can you plug the two ballast resistor connectors in on the wrong ends?
                                As in mix the two single spades side for side and still work the same?
                              • pishta
                                19,830
                                9200
                                Oct 13, 2004
                                Tustin, CA
                                Local Time:
                                5:56 AM
                                the dual resistor has 2 resistor values (5 ohm feeds ECU, and .5-1.5 ohm to feed the coil) , but they are not polarized, hook em in any direction you want. Here is an old quote, take it or leave it:
                                "...Ok... let's clear up
                                dual ballast provides two sources by two diff resistances. One is 5 ohms ( secondary ) which feeds the stock 5 pins ECU, and the other one is anything between 1.5 or .5 ohms ( Primary ) which feeds the coil.
                                single ballast just provides power for the coil. Resistance varies depending on which one and application, between 1.5 and .25 ohms
                                on 5 pins ECU, the 5th pin takes ONE POWER SOURCE from the secondary ballast resistor on dual piece.
                                on 4 pins ECU, the secondary resistor is not anymore outside, was moved to INSIDE the ECU... that's why the pin is gone
                                you can fit a 4 pins ECU on an stock 5 pins system without problem, simply the secondary resistance power will be going to, ANYWHERE... the pin is not there
                                you should NOT use the 5 pins ECU, on a system set to 4 pins. Probably your car will start up and ride around, what doesn't mean will work properly..."
                                • prorac1
                                  1,510
                                  1371
                                  Sep 29, 2012
                                  Martin, Mi
                                  Local Time:
                                  8:56 AM
                                  Wiring has begun.
                                  Thank you to everyone for the help. I have a much better understanding of the chrysler starting and charging circuits and how they intermingle with the ignition system. Thank you again.
                                  Come to find out……we have a 5 pin ECU. In the pictures I was looking at the center screw blocked the 5th post.
                                  Not a big deal, we had a brand new 4 bin ballast on hand.
                                  We also bypassed the bulkhead with the main hot wires, cleaned all connections and terminals with evaporust, wired the alternator charge wire to the starter relay, and ran new heavier guage wires to the interior, the battery (to feed the relay), and from the starter solenoid to the starter relay.
                                  We added in the electronic ignition, square back dual field alternator, and electronic regulator as well.
                                  So far it's turning out great.
                                  As the pictures show we are slowly "looming" everything together in an organized fashion.
                                  IMG_4804.JPG IMG_4805.JPG IMG_4806.JPG IMG_4810.JPG IMG_4814.JPG IMG_4815.JPG IMG_4816.JPG IMG_4817.JPG IMG_4818.JPG IMG_4819.JPG
                                  • Like Like x 1
                                  • prorac1
                                    1,510
                                    1371
                                    Sep 29, 2012
                                    Martin, Mi
                                    Local Time:
                                    8:56 AM
                                    Yep……I count four pins
                                    Nope……there's the 5th pin. Lol
                                  • 67Dart273
                                    48,278
                                    16312
                                    Oct 14, 2010
                                    Idaho
                                    Local Time:
                                    5:56 AM
                                    ^^I doubt you have a 5 pin ECU. You cannot tell by looking. Many especially aftermarket (that is one) ECU have 5 PHYSICAL pins but the 5th is unconnected. Without ohms test to the rest of the pins you cannot tell. But that is a "newer looking aftermarket" and I'd bet it is a 4. Running a 4 pin ballast won't hurt, it simply doesn't use the other section
                                    How to tell for sure? Easy. After you get it all wired up and running. Measure all 4 pins with the engine running. The two which are jumpered together will measure "same as battery" that is whatever the running V is (13.8--14.2) If the other two are both used, they will measure somewhat LESS than that showing that current is dropping voltage through them. If one is unused, it will be same as the supply pins
                                    • Like Like x 1
