AustinGriggs
#MoparVsBrandXstreetcarShowdown
- October 19, 2019
- 10am (Be on time if you want to qualify)
- Jakes Dragstrip (3041 County RD 94 Danville, AL 35619)
- Austin’s Muscle Car Clinic
-This is a Dragrace event where you will climb the ladder to be the fastest of 3 classes, Class rules are below. These rules are intended to create a competative enviroment for regular high performance street cars. In short the lowest class if for N/A cars that dont have all the advantages of a drag car like a power adders, transbrake, 4 link, and monster tires.... We want you to have traction problems in this class if you bring monster power, but you have to do it with an engine that could have been put in your car the decade your car rolled off the assembly line, and it can't be a raceblock.... For Raceblocks, boost, and nitrous you will have to move up to the next class where rules get alittle more relaxed.... as for the last of the 3 classes it is designed for folks that have rather serious race cars; so long as they retain the factory frame and doors.... Questions, I hope you will find the answers below. Mind you, this is the internet and I know some may or may not agree with all or some of the rules.... Cool, but don't expect me to change anything or argue my point. This is all for the fun and enjoyment of these old cars, always good turnouts, lots of bench racing in the pits, tons of roadside help if your car has trouble during the 40+ mile backroad cruise leaving and returning to Jakes Dragstrip. If you seen the (MotorTrends House of Muscle ep:8 Ratty Muscle Cars), then you have an idea of the shindig we put on called the #NoShineShitList. This is a Mopar event.... with a twist. Going to have some hand picked competition for you to fight through in addition to the Dodges and Plymouths! Hope some of you make the trip, we usually have between 6-8 states represented at our races. If you are coming.... Where are you coming from?
--------Gladiator Street (GS)---------------
*Must be 1999 or older RWD Vehicle
*Pump Gas ONLY!
*Tires-295 or smaller TREADED Drag Radials, NO SLICKS!!! (Manufacturer must not "Prohibit from Street Use")
*Must prove valid Registration and Insurance
*Must be capable of Street Driving 40+ miles the day of the events
*Factory STYLE rear suspension, Mandatory!
*Factory frame, Mandatory!
*Period Correct Engine / Drivetrains (ANY LA, Magnum, B, RB, Gen 1 or 2 HEMI swaps OK)
*No Aftermarket Race Blocks
*No Power Adders (Nitrous, Turbochargers, or Superchargers)
*No Transbrake / Air-Shifter / Secondary Rev Limiter/ Launch Controller / Delay Box / Throttle Stop
*No Dominator Carburetors or Throttle body size equivalent
***Basically if you bring a serious drag car you will be moved up to the next of 2 classes accordingly***
-----------Barely Legal (BL)-------------
***Same Gladiator Street (GS) rules unless exempt below***
*Any and All Motor / Drivetrain swaps WELCOME!
*Power Adders (Nitrous, Turbochargers, or Superchargers) WELCOME!
*Dominator Carburetors or Throttle body size equivalent WELCOME!
*All Radial Tires 295 or smaller WELCOME! (ET-Street Pro, ET Pro Drag, ET-Street-R, Hoosier DOT)
-----------Bandit Street (BS)-------------
***Same Barely Legal (BL) rules unless exempt below***
***No Street driving required in this class, there for no need for Registration and Insurance***
*Aftermarket Race Blocks WELCOME!
*Any Tire you want to run ( 295 or Bigger Radial, Bias-ply, Slick)! WELCOME!
*Any Rear Suspension WELCOME! 4-links etc...
*Transbrake / Air-Shifter / Secondary Rev Limiter/ Launch Controller / Delay Box / Throttle Stop WELCOME!
*ALL FUELS WELCOME!
*Mufflers, Battery/Charging systems OPTIONAL!
- October 19, 2019
*Pump Gas ONLY!
*ALL FUELS WELCOME!
