Moroso 10 inch Deep 8 Qt Pan
SSG_Karg
Enhanced member
Pennsylvania
I have that pan on my current build. Almost ready to add oil and prime and was wondering this exact thing.
Anyone running this pan with less than 8 qts. I run mine with 7 just wondering.
Are you using that pan in the car in your avatar? That thing looks mighty low. You haven’t smashed it yet?
'68cuda416
kansas city
I have run extra capacity pans with a quart less and had no issues, I now use custom aluminum pans but my first engine was with that pan and all was good.
OldmanRick
Ladson, Sc
Used quite a few of those pans on different makes in the 70s/80s. Pretty hard to pump one dry with reasonable oil pressure, 70lbs and under. Especially in a quarter mile car. Unless your launching 4' in the air, 7 or even 6 qts shouldn't be a issue. One exception was a 428 fe Ford i did that had 95/100 lbs of pressure. Those engines required that for those heavy *** cranks, lol.
