DGrace
Installing my Moser Fab 8.75 & axles and noticed the supplied seals are "no name" and I want to replace with a name brand. They say " Taiwan" and 3200 - nothing cross references. Contacted Moser but not much help, they said they could supply replacements but they would be the same as what I have. The supplied seals measure 2.0690" OD and about 1.5" inside (without compressing the rubber seal). Anybody run into this and know a seal that will work? At work now but when I get home, I'll measure the shaft diameter and see if that'll help my search.Thank you.
