motorhome engine and trans
dart67
NH
Would a 77 dodge motorhome with a 360 engine and 727 trans fit into a duster? (mainly wondering about the trans?)
Thanks
I got a 360 727 out of a 73 motorhome and the tailshaft on the 727 had to be swapped. But it does have the 4 pin gear set
Thanks
Engine yes, trans maybe. They used 2 styles of transmissions in motor homes. One style is just like a car and the other uses a real short tail shaft with a big parking brake assy. on the back. To change the latter to a car style trans. means completely disassembling the trans. to replace the output shaft cause the output shaft goes in from the front.
