mounting a glass hood scoop on a steel hood
Mopar Body and Trim
  1. burrpenick
    burrpenick '69 Barracuda
    414
    25
    Jan 16, 2008
    Florida
    Local Time:
    1:37 PM
    I know many say they always crack if glassed on a steel hood, but what about riveting- is there a method where the rivet head could be countersunk and covered?
  2. Demonracer
    Demonracer 71 Demon 00 Ram 16 Chrysler 300S 05 Caravan FABO Gold Member
    4,891
    2860
    Jan 31, 2010
    Cleveland, Texas
    Local Time:
    1:37 PM
    Is the scoop going to be functional?
  3. moparmat2000
    moparmat2000 FABO Gold Member FABO Gold Member
    18,890
    7874
    May 13, 2010
    Grand Tetons
    Local Time:
    1:37 PM
    The cracking problem probably has to do with the different rates of expansion and contraction under heat and cold cycling of steel sheetmetal vs the fiberglass scoop. What can possibly bridge that gap between those rates is using JB weld to bond and rivet the scoop in place. This should help bridge that rate of expansion, then use an autobody filler such as dyna glass over the JB weld glue joint.
  4. burrpenick
    414
    25
    Jan 16, 2008
    Florida
    Local Time:
    1:37 PM
    well not really..........
  5. burrpenick
    414
    25
    Jan 16, 2008
    Florida
    Local Time:
    1:37 PM
    Anyone have an old/maybe damaged scoop to sell?
  6. dodgedifferent2
    dodgedifferent2 Well-Known Member
    2,650
    461
    Aug 8, 2008
    southwestern, Ontario
    Local Time:
    1:37 PM
    I pop riveted a six pack scoop on to my steel hood.
    I then fiberglassed things smooth.
    I fine tuned with some body fill and had it painted.
    Has been about 4 years. No cracking as of yet.
    Mine is functional. I also braced the underside hoping to take out some flex.
  7. Mouse action
    Mouse action Well-Known Member
    385
    712
    Oct 16, 2019
    Brooklyn
    Local Time:
    2:37 PM
    Mine had the studs already in the scoop.
    I sealed it around with a soft door edge mouldings. DDDA31B4-AC34-4C13-8E8D-C65E99D84990.jpeg
    • Like Like x 2
    • Agree Agree x 1
    • A Body 440 WHY NOT
      A Body 440 WHY NOT Well-Known Member
      358
      140
      Sep 28, 2019
      Jersey
      Local Time:
      11:37 AM
      Body panel adhesive
      Crazy strong
      • Like Like x 1
      • Agree Agree x 1
      • str12-340
        str12-340 FABO Gold Member FABO Gold Member
        1,784
        1050
        Dec 26, 2012
        Vashon, WA
        Local Time:
        11:37 AM
        why not go the Ma Mopar route and put studs in the scoop and bolt that baby on - no crack problem there...
        • Agree Agree x 1
        • moparmat2000
          18,890
          7874
          May 13, 2010
          Grand Tetons
          Local Time:
          1:37 PM
          I put an aftermarket dart sport scoop on my kids 69 barracuda hood. The stud holes in this scoop were dpot on for the factory access holes in the structural web underneath. It's going to stay a bolt on setup. Not moulding it in. You can get fiberglass bolt on hoods from stinger fiberglass with a six pack scoop already moulded in.
        • GREEN DART 5
          GREEN DART 5 Well-Known Member
          101
          80
          May 31, 2017
          NOR-CAL
          Local Time:
          11:37 AM
          Last year I added a fiberglass scoop to a metal hood with pop rivets about every 2 1/2” then used Bondo to mould it in. The rivets aren’t perfectly lined up because I tried to hide them on the bottom side of the hood.
          Used this method back in the 80’s on a different hood and it held up great.
          However you mount it, make sure it will not flex. BCEECCD2-C09D-4584-B373-0A74059B93B6.jpeg
          • Like Like x 1
          • moparmat2000
            18,890
            7874
            May 13, 2010
            Grand Tetons
            Local Time:
            1:37 PM
            What also helps is when you rivet it on, to use backup washers under the rivet rails to reinforce the mounting. This means you need somebody to help you by holding the washers in place while you pull the rivets, but makes the attachment a bit stronger than just using the hood sheetmetal.
            • Agree Agree x 2
            • Like Like x 1
            • Daves69
              Daves69 Well-Known Member
              5,571
              3890
              Feb 20, 2011
              WestOfChi
              Local Time:
              1:37 PM
              Lol, a :eek: "riveting" experience .............
              • Like Like x 1
              • moparmat2000
                18,890
                7874
                May 13, 2010
                Grand Tetons
                Local Time:
                1:37 PM
                If you ever want to get perfect spacing for rivets it's a simple math equation. Total length from point A to point B in a straight line divided by the number of total spaces you want between the rivets. This will give you the rivet on center spacing in decimal form. I use it all the time doing sheetmetal patches on aircraft.
                • Like Like x 1
                • Dfr360cuda
                  Dfr360cuda Diagnosis... Plum Crazy.
                  1,722
                  1095
                  Aug 30, 2012
                  Finleyville, PA
                  Local Time:
                  2:37 PM
                  1976 to 78 I had a Camaro. I put an L88 scoop on it with fiberglass. Never had a problem. It was functional so a lotta heat was not trapped under the hood.
                • leblanc
                  leblanc member 2883
                  2,204
                  358
                  Jun 5, 2006
                  Dieppe,NewBrunswick,Can.
                  Local Time:
                  3:37 PM
                  My 76 Dart Sport Got its fiberglass scoop put in in 78-9 by a good body shop owner. He put about 3/4'' of body filler and sunk in the scoop. The first crack appeared about 4 years ago. It never moved!!!
                • burrpenick
                  414
                  25
                  Jan 16, 2008
                  Florida
                  Local Time:
                  1:37 PM
                  How easy did the scoop bend/conform to that ridge in the center of your hood. My hood is probably a 67 and has two ridges that the hood inserts laid into. Thanks, George
                • Daves69
                  5,571
                  3890
                  Feb 20, 2011
                  WestOfChi
                  Local Time:
                  1:37 PM
                  Piece of cake. The '69 slope is not steep or abrupt there. PM sent.
                  358
                  140
                  Sep 28, 2019
                  Jersey
                  Local Time:
                  11:37 AM
                • moparmat2000
                  18,890
                  7874
                  May 13, 2010
                  Grand Tetons
                  Local Time:
                  1:37 PM
                  Sure, you can use 100° countersink pop rivets, and countersink em slightly below the top surface of the scoop, then skim body filler or dynaglass over them, but it will eventually crack around the rivets because the heating and cooling rates of the parts are different. The composites and glues of today are definitely better than 50 years ago, so it may last longer than this type of job used to last.
