mounting turndown tailpipes
Mopar Exhaust Systems
  1. pinkmeepmeep
    pinkmeepmeep Member
    6
    0
    Feb 26, 2014
    N.W. Washington
    Local Time:
    11:45 PM
    No, I don't want to breed with them, I just would like to see some survivor pics so that I can clamp the turndown tailpipes in the right location on my duster. I have dougs headers, and accurate exhaust so I need to determine the proper place to clamp the tailpipe before I join the two. Is it clamped before or after the bend that begins the turndown sequence? A pic would make it clear to me. To clarify, the tailpipe comes out of the muffler, goes over the rear end, then it has a long straight segment. At the end of this segment it has a bend up, a short straight length, and then terminates in a bend down. Not sure if the clamp goes before the first bend, in the bend itself, or on the short straight upsweep piece? I have been surfing around and I just cant seem to find any pics that show this. I am starting to feel a bit feeble in my sleuthing abilities as well as my narrative skills in trying to explain such a simple concept! Thank you much.
  2. oldkimmer
    oldkimmer FABO Gold Member FABO Gold Member
    10,453
    1296
    Nov 11, 2006
    Kindersley, Saskatchewan,
    Local Time:
    11:45 PM
    ..........Is there not a spot on the frame rail where the mount should bolt too...........kim.....
  3. pinkmeepmeep
    pinkmeepmeep Member
    6
    0
    Feb 26, 2014
    N.W. Washington
    Local Time:
    11:45 PM
    I have the proper hangers installed in the proper location, I am trying to figure out where to clamp the pipe to them
  4. Tom Swope
    Tom Swope Well-Known Member
    56
    10
    Mar 2, 2006
    Local Time:
    9:45 PM
    The hanger clamp tab mounts to the tailpipe on the straight section right before the tailpipe starts bending upward. Usually the tab faces toward the rear on an a-body.
