[Found!] MP P4529556 Pushrods
Cars and Mopar Parts Wanted
Thread Status:
  1. xLURKxDOGx
    xLURKxDOGx "An angel fat, at satan's feast" FABO Gold Member
    2,937
    786
    Dec 27, 2013
    PHX
    Local Time:
    12:32 AM
    Contact Seller
    Looking for new/used set. This is for T/A 7.24 adjustable/hydraulic.
    Thanks,
    Jake
  2. pishta
    pishta I know I'm right....
    14,894
    4533
    Oct 13, 2004
    Tustin, CA
    Local Time:
    12:32 AM
    What the part, pushrods?
  3. 4spdragtop
    4spdragtop FABO Gold Member FABO Gold Member
    26,123
    5657
    Aug 28, 2009
    Ontario
    Local Time:
    2:32 AM
  4. xLURKxDOGx
    2,937
    786
    Dec 27, 2013
    PHX
    Local Time:
    12:32 AM
    Yes. Guess I should have put that.
    Jake
  5. Oldmanmopar
    Oldmanmopar Going left turning right FABO Gold Member
    6,826
    2001
    Jan 8, 2009
    Danielsville Pa.
    Local Time:
    3:32 AM
    Smith Bros. Push rods. They will make you what ever you need. I had to have a set made for my motor. I went to Ball & Ball ends non oil instead of a straight hollow with oiling. They were the only company that new my problem with and made what I needed.
    I use cup adjusters and the adjuster was hitting the side of the push rod. The ball end eliminated this problem. The motor was used for 6 years but because of the black anodized coating you could see they were hitting. This caused the push rod to gull. They were also oil through and we put non oil.
    Check out the angles of these push rod. Just think of the flex with these heavy springs. We use an oil through stud which is indexed so we can oil through the rockers shafts instead of sprayers. Critical for rocker oiling if you use studs. Information is always good to have
    • Like Like x 1
    • 694spd
      694spd Well-Known Member
      826
      190
      May 2, 2014
      Upstate NY
      Local Time:
      3:32 AM
      PM sent...
    Thread Status:
