MRL Performance
Let me introduce you to our new line of engines, The Classic Cruisers. First up is our Classic Cruiser 360. They are our most basic, entry level engines. What does that mean? Well its basically a warmed over stock 360, but with some MRL Performance touches.
They offer real good power, great street manners, good economy and rock solid durability.
Follow along.
360 LA block
Hyper pistons w/coated skirts
Stock crank reconditioned and balanced
Stock rods NEW
Aluminum roller rockers
Stock heads 2.02/1.60 SS High flow valves mild port work
Stock type oil pan, NEW
Hydraulic flat tappet cam w/Lunati Micro Trol Lifters
Weiand Stealth Aluminum dual plane intake
Chrome valve covers
Stand alone ignition, no box required!
Quick fuel 750 vacuum secondaries carb w/electric choke
High flow water pump
High flow oil pump
New flex plate for neutral balance T/C
New damper
This 360 is mild. Idles well at 750rpm and pulls 15inches of vacuum. Nice sound, but not lumpy at all.
Now for the power. Peak Power is 375HP and 410TQ
Pulls hard to 6000rpm and pours the torque on early! It makes 400tq+ from 3000-4400rpm and 350HP+ from 4600-6000+rpm.
All this from Factory parts and a small 228* cam w/.480" lift!
In Stock and Ready to Ship!
Spring Time Special $5200
Follow along.
360 LA block
Stock rods NEW
Chrome valve covers
High flow oil pump
New damper
