Muriatic acid
General Discussion
  1. DodgeLad
    DodgeLad There's no place like home FABO Gold Member
    1,284
    962
    Jan 15, 2014
    The Duke City
    Local Time:
    5:08 AM
    Holy frijole...I haven't poured anything that smoked since college chemistry class. Got a whiff of it and I'm sure that was a blunder. I'm amazed you can still buy this stuff. I got some to clean up ceramic planters and I'm thinking I should have just got new pots. I was going to do the toilet clean with it, but that's out.
    Any experience with this stuff?
  2. TrailBeast
    TrailBeast AKA Mopars4us on Youtube
    21,406
    8998
    Mar 11, 2011
    Arizona
    Local Time:
    4:08 AM
    Yea, I use it all the time for badly rusted stuff and removing water deposits from glass.
    10 minutes and rust is gone completely.
    You gotta be careful with this stuff, and NEVER breath the fumes or you could end up with chemical Pneumonia and basically drown in your own fluids. (not good)
    It's watered down hydrochloric acid.
    • Thanks! Thanks! x 1
    • SpeedThrills
      SpeedThrills FABO Gold Member FABO Gold Member
      1,713
      441
      Jun 3, 2008
      Very South Jersey
      Local Time:
      7:08 AM
      It's used in small engine repair to remove aluminum deposits from the crankshaft where the crank rides on the aluminum engine case without a bearing when the engine kicks a rod or rods from low oil. Whew, my English teacher wouldn't like that run-on. lol
      Yeah, they take the "oomph" out of carb dip and a zillion other things, but we're still "ok" with that stuff.
      • plymouth67
        plymouth67 It be a lot cooler if you did...
        1,198
        1454
        Sep 13, 2010
        illinios
        Local Time:
        6:08 AM
        Use it every year when I get the pool up and going....pour about 5 gallons in the pool the kill the ph level....chlorinate the shit out of it and off we go!!! Its nasty stuff for sure...
        • DodgeLad
          1,284
          962
          Jan 15, 2014
          The Duke City
          Local Time:
          5:08 AM
          it works well I see, ceramic pot looks good now...I was going to do this
        • Slantsix64
          Slantsix64 Well-Known Member
          2,675
          1043
          May 11, 2014
          SGV
          Local Time:
          6:08 AM
          i used it in my slant six head cleaned the shit out of it, then i had to run water and baking soda to neutralize it
        • TrailBeast
          21,406
          8998
          Mar 11, 2011
          Arizona
          Local Time:
          4:08 AM
          I wouldn't do that unless the house was cleared of everyone and I had a good chemical mask.
          Take it off and outside I would do it.
          • Agree Agree x 1
          • George Jets
            George Jets 1967 Dart 2 Door FABO Gold Member
            2,566
            3863
            Jan 18, 2019
            Farmington MN
            Local Time:
            6:08 AM
            Yes, stuff is nasty to use, use a charcoal respirator and do it outside. Then rinse your parts or whatever with baking soda and water to neutralize the acid, final rinse with distilled water helps it not to flash rust quite so quick when working with steel.
            Rinse and blow dry right away.
            Used it on a small area on the under body of a mopar just in front of the rear wheels on the underbody.
            Clean, Dry, Prime and Paint . . Brand New
            Good bye surface rust.
            For sure use saftey glasses and rubber gloves when working with the chemical acid. Long sleeve shirts too, one spec can burn like Hell. Fush with water if you get any on you.
          • pikewi
            pikewi Comfortably numb
            212
            59
            Oct 18, 2010
            WI
            Local Time:
            6:08 AM
            I always used it to clean bricks after laying them. I have no fingerprints
            • Like Like x 1
            • AJ/FormS
              AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
              18,894
              6901
              Jan 19, 2014
              South-Central Manitoba,Canada, 900ftelevation
              Local Time:
              6:08 AM
              Hyup, same uses as above.
              With hard well-water, it makes short work of the scale. for 2 or 3 bucks a jug back in the day, it saved me from having to buy many a new toilet.
              And Like said; it eats aluminum, so great for cleaning up piston-transfer in a cylinder. But man it's hard on the nose if yur not careful.And yes it will dissolve your fingerprints........
              • Agree Agree x 1
              • reddog
                reddog Well-Known Member
                105
                89
                Jul 30, 2009
                Davisburg, Alberta
                Local Time:
                5:08 AM
                Be careful with this stuff. A very strong acid with low pH. Used to etch concrete amongst other things. Make sure you have all the proper PPE when handling and never add water to this (or other acids).
              • Danny Boy
                Danny Boy Well-Known Member
                103
                90
                Sep 13, 2018
                Land of Enchantment
                Local Time:
                5:08 AM
                My son cleaned the floors of his garage and didn't ventilate properly.
                Had extensive pitting damage to chrome/brightwork on his vehicle and chromed parts
                Be careful, chrome easier to replace that one's lungs!
                • Like Like x 1
                • Unconventional
                  Unconventional Well-Known Member
                  10,556
                  10493
                  Apr 17, 2017
                  Santa Maria, Ca.
                  Local Time:
                  4:08 AM
                  Cleaning concrete off crusty mixer trucks, doesn't take much.
                  That pesky galvanizing on that pipe you need to weld, no problem.
                  Well ventilated area, don't wear clothes you're not afraid to throw away.
                  • Like Like x 1
                  • Jadaharabi
                    Jadaharabi FABO Gold Member FABO Gold Member
                    7,435
                    8068
                    Jan 8, 2016
                    Peoria, Illinois
                    Local Time:
                    6:08 AM
                    I think it is also called "Milk Stone Remover". Used by dairys to flush the milk house pipes.
                  • pishta
                    pishta I know I'm right....
                    18,106
                    7583
                    Oct 13, 2004
                    Tustin, CA
                    Local Time:
                    4:08 AM
                    Used that to dip my rusty rims in. Cleaned them up like magic. Flash rusted in s matter if minutes but it wipes off. Goid call on distilled water rinse after baking soda. Neutralized acids using a base creates salt,vthays what you need to get off to prevent rust. A plastic yard waste can from home depot was perfect size for a 14 Rallye rim. Fill with gallon buckets of water to see how much it will take to just cover rim, then dump and add water minus 2 gallons. Fill rest with pool acid slowly to avoid splashing. Always add acid to water or a violent reaction can occur adding water to acid! Let it set checking every 10 minutes. Then remove and dunk in neutralizing bath of base, baking soda mix. Finsl rinse or spray down with distilled water. Does pool acid etch toilet bowl?
                    • Like Like x 1
                    • 67Dart273
                      67Dart273 FABO Gold Member FABO Gold Member
                      44,358
                      11875
                      Oct 14, 2010
                      Idaho
                      Local Time:
                      4:08 AM
                      Muriatic is same stuff as battery acid, different concentration.......hydrochloric. Also, we used to use it to clean water-to refrigerant heat exchangers, "coil clean" I still have some it. THAT last stuff is pretty concentrated, and you want to be careful
                      Back when we had "real" auto parts stores, many carried battery acid, and if you had a container you could buy a little, or with a little more money, buy a container. They came in different sizes, don't remember. Seems like the smaller was about enough to fill a dry battery, and the larger container was maybe a couple? gallons.
                      And back when we had "real" chemical supply houses, ----and they weren't worried about registering and licensing every damn thing, they could also sell you various types
                    • Jadaharabi
                      7,435
                      8068
                      Jan 8, 2016
                      Peoria, Illinois
                      Local Time:
                      6:08 AM
                      Battery acid is sulfuric acid not hydrochloric acid.
                      Your muriatic acid is hydrochloric acid.
                    • reddog
                      105
                      89
                      Jul 30, 2009
                      Davisburg, Alberta
                      Local Time:
                      5:08 AM
                      Yes and H2SO4 is bad and HCl is badder!
                      • Agree Agree x 1
                      • BigBlockMopar
                        BigBlockMopar BigBlockMember
                        1,753
                        752
                        May 1, 2011
                        Netherlands
                        Local Time:
                        1:08 PM
                        Citric acid smell and is much friendlier and still does the job of derusting most stuff.
                        It also comes in soda drinks and soaps.
                      • DodgeLad
                        1,284
                        962
                        Jan 15, 2014
                        The Duke City
                        Local Time:
                        5:08 AM
                        'aqua regia' = nitric acid + hydrochloric acid...first substance discovered that would dissolve gold
                        anyway, I'm never opening that jug again, not worth it to me...thanks for all the replies
                      • 67Dart273
                        44,358
                        11875
                        Oct 14, 2010
                        Idaho
                        Local Time:
                        4:08 AM
                        OH geez but it IS coil cleaner LOL
                      • diymirage
                        diymirage HP@idle > hondaHP@redline
                        19,932
                        14165
                        Oct 12, 2012
                        michigan
                        Local Time:
                        7:08 AM
                        reminds me of this little diddly
                      • Jadaharabi
                        7,435
                        8068
                        Jan 8, 2016
                        Peoria, Illinois
                        Local Time:
                        6:08 AM
                        Lol I've never tried it for cleaning a coil.
