Csommers
This car started life as a Dart GTS. It looked like it has had a rough life. I do not know when but it was converted to a racecar. Pretty poor conversion but worked for them. I bought the car for $800, Car has a rollcage, ladder bar mounts, tubs and subframe connectors. The whole front clip is gone. The floor, tubs, and quarters are rusted. Also discovered about 10 lbs. of bondo on the passenger side quarter where it hit a wall. Which would explain why the passenger side front frame is bent. Also found out the rear passenger frame is buckled. So I have already stripped just about everything out. I managed to pick up a used motor home 440, 340 K frame, tunnel ram with dual quad carbs and fiberglass fenders so far. Next to come is the floor, quarters and frame rails. I will more than likely order all of that from AMD. The guy who sold me the car has about 8 more A bodies including 3 darts.I will be pulling a hood for mock up and trunk to mock. The trunk and hood will more than likely be fiberglass when I am done. This car, in the end, is going to be a street legal drag car. I want to be able to cruise the weekends, go to local car shows and hit the track when I want. Here are a couple pictures in no particular order so you can laugh at it.
