My car is very loud on bumpy streets. What do I look for?
Discussion in 'Suspension, Steering and Chassis' started by yellowghost, Sep 6, 2018.
  1. yellowghost
    yellowghost Well-Known Member
    142
    6
    Jun 6, 2010
    Canada
    Local Time:
    2:43 PM
    My 73 plymouth is very loud on bumpy streets. Very loud slapping and banging sounds from the front end. I rebuilt the front suspension a few years back. However I followed the repair manual and it did not mention anything about marking the position of the torsion bars. I put them back in the same positions ..just not in the same location in the frame. I reckon they were worn out anyway and plan to install new bars next summer. I changed the transmission mount as well. Are there any other things I could look at. Would worn motor mounts cause these loud bangs? Dont even enjoy driving the car anymore. Smooth streets are hard to come by where I am.
  2. Bodyperson
    Bodyperson A little sketchy
    1,595
    1246
    Nov 26, 2015
    Under The Big Sky
    Local Time:
    1:43 PM
    That's a loaded question. How confident are you on the rebuild? Did it make noise right away? You must of had it aligned. Align tech should have shook it down for loose suspension parts. Exhaust hitting? Wheel bearings not adjusted correctly? Look at simple stuff first. Noises are elusive. They can telegraph.
  3. 72bluNblu
    72bluNblu FABO Gold Member FABO Gold Member
    8,972
    2912
    Nov 28, 2008
    NorCal
    Local Time:
    12:43 PM
    If you're running the stock torsion bars and your car sits at or below factory ride height then those noises are likely you bottoming the suspension out. The stock torsion bars are VERY soft, they don't have enough spring rate to go any lower than the factory height.
    Also, when you say you rebuilt the front suspension, what did you change? If you skipped the LCA bushings, they could be the source of your noise as well.
    • Agree Agree x 1
    • DesertRat
      DesertRat FABO Gold Member FABO Gold Member
      2,579
      1412
      Jan 22, 2005
      Moses Lake, Washington
      View My Photos
      Local Time:
      12:43 PM
      If you did a disc brake conversion check the caliper mount bolts. You can check that by giving it a little brake pedal and see if the noise gets better.
      • Agree Agree x 1
      • pishta
        pishta I know I'm right....
        13,541
        3301
        Oct 13, 2004
        Tustin, CA
        View My Photos
        Local Time:
        12:43 PM
        sway bar mounts/bushings could be shot too.
      • RustyRatRod
        RustyRatRod Just another dumbass. FABO Gold Member
        47,464
        12482
        Jun 7, 2010
        Georgia
        View My Photos
        Local Time:
        3:43 PM
        If you could post a video with good audio that would be helpful.
      • Bigdummy
        Bigdummy Not a Nova
        7,538
        1588
        Dec 26, 2006
        Cleburne,Tx
        View My Photos
        Local Time:
        2:43 PM
        Shocks?I had some monroe's that didnt last long at all
      • RogerRamRod
        RogerRamRod The Older I Get, The Faster I Was
        738
        308
        Jul 5, 2011
        Chesapeake VA
        View My Photos
        Local Time:
        2:43 PM
        Stay off bumpy Streets
        Edit; Oh, sorry now I read your post. Carry-on with the aforementioned suggestions.
      • 1969VADart
        1969VADart FABO Gold Member FABO Gold Member
        2,066
        402
        Aug 19, 2013
        Fredericksburg, VA
        Local Time:
        3:43 PM
        I would say the sound could be deceiving. I realized that much of my noise in my car was the gas tank rattling against the exhaust but it sounds almost like it is coming from under my drivers seat.
      • yellowghost
        142
        6
        Jun 6, 2010
        Canada
        Local Time:
        2:43 PM
        Thanks everyone. First off..I changed everything. All bushings and parts. I used poly bushing in the upper control arms but it was making the noises before that. The steering link is pretty close to the exhaust pipes but I dont see any damage on the pipes. I reckon there would be. Has disc brakes already and holding the brakes improve it. And no sway bar installed.
        Could you expand on that torsion bar comment? My build sheet says I have 891 and 890 bars. My car has the 5.3L motor. I have a hard time understanding torsion bars. They say stiffer bars give harsher ride..but isnt that what you need to absord potholes and things? A soft torsion bar would just bounce the car around and bottom things out no?
        Also in the spring my tires were very low on air and the ride was much more quiet. It got louder after I filled to specs. That might be a clue no?
      • mbaird
        mbaird mbaird FABO Gold Member
        3,948
        1189
        Dec 10, 2005
        boise, Id
        Local Time:
        1:43 PM
        I rebuilt 2 front ends and came out with bumpy harsh noisy suspension. What I came to find out was that there is a sequence to retightening all the components. I followed the advice of a few FABO members on my Barracuda this year and it is MUCH better.
      • vntned
        vntned Well-Known Member
        1,025
        402
        Apr 28, 2012
        Gibsonville NC
        Local Time:
        3:43 PM
        I'd look for smoother streets!
      • DesertRat
        2,579
        1412
        Jan 22, 2005
        View My Photos
        Local Time:
        12:43 PM
        If holding the brakes improve it, check your caliper mount bolds, they could be loose. It happened to me, took tire off, found loose bolts, tightened them up and problem was solved!
      • 72bluNblu
        8,972
        2912
        Nov 28, 2008
        NorCal
        Local Time:
        12:43 PM
        If holding the brakes improves it, look for loose brake parts and check the wheel bearings- ie, think about parts that won't be able to move around as much if there's pressure on the brakes to hold them in place.
        The noises likely got worse when you aired up the tires because with more air in the tires the sidewalls will be stiffer, so they're absorbing less of those bumps and transmitting more to the suspension.
        As for the torsion bars, 890/891 bars are .85" in diameter, which is stock for a 318 car with no A/C. The have a wheel rate of only 100 lb/in. Think about that for a second. You have about 5" of total suspension travel or so. Heck let's call it 6" for even numbers. If your ride height is adjusted so the control arm has equal travel in both directions, that means 3". Which means that 300 lbs of added force will bottom out your suspension. Now think about a 3,500 lb car traveling down the road at 40 mph and hitting a pothole. Think that's more than 300 lbs of additional force? Yeah of course it is. And that assumes you have equal travel, if the car is lowered a little from factory height, which is probably is unless you specifically set the factory height, that means it'll take less than 300 lbs of force to bottom your suspension. These cars bottomed the suspension even with the factory bars at the factory ride height, the bump stops are designed to be progressive because of that, to take the harshness out of bottoming the suspension all the time.
        The torsion bars from the factory were small because these cars came with bias ply tires, which have very little grip and therefore don't transmit a lot of cornering force to the suspension. And because shock technology wasn't great, and the demand in the 70's was for cars that rode really soft- some of it was just marketing. Fast forward to now and you have radial tires, which transmit more cornering forces. You have better shock technology available to deal with higher wheel rates, and we know better than to want a car that rides like you're floating on a marshmallow because it'll float and flop all over the road, just like these cars do from the factory.
        So how big do you want the torsion bars to be? It's a trade off, just like EVERYTHING with suspension. If the bars are too stiff, the suspension will move very little and all of that force will be transmitted to the car- it'll rattle your teeth out and won't keep the tires on the road, which is the whole point of suspension. If they're too soft, the suspension will bottom out all the time, which will create a crappy ride because of all the suspension components crashing together and unpredictable handling too. What you want is suspension that is stiff enough not to bottom out all the time, but still soft enough that it absorbs as much of the road forces as possible. Ideally, the softest suspension that doesn't bottom out frequently is what you want.
        In my opinion, there's no point running bars that are smaller than 1" on anything that sees frequent street use. That size bar has about a 200 lb/in rate depending on the manufacturer, which is double the factory rate. That also means running better shocks, because if you do that the ride won't be harsh. Shocks have to matched to the wheel rate, if you run KYB's with 1" or larger bars the ride will be harsh, because KYB's are lousy shocks for larger bars.
        Now, does any of the torsion bar stuff have ANYTHING to do with what's making noise on your car right now? No idea. It does sound like you're bottoming out, but that's just from what you're saying. Pictures of your suspension would help, so would a video or sound clip of the noise. And you need to put the thing up on jackstands and look for loose or broken parts at the very least. Lower control arm bushings are easy to damage on install, and the rubber quality of the re-popped bushings now has gone down considerably, so just because there was a recent rebuild doesn't mean you can assume any of those parts are good.
      • dartnabout
        dartnabout FABO Gold Member FABO Gold Member
        9,972
        2546
        Aug 27, 2007
        Central PA
        Local Time:
        3:43 PM
        Isn't loud and bumpy what we are all looking for?
      • yellowghost
        142
        6
        Jun 6, 2010
        Canada
        Local Time:
        2:43 PM
        Will take a video this weekend. And I suppose also measure the ride height. A search turned this up:
        "Ride Height 1 5/8" Difference between measured points (bottom of lower ball joint & torsion bar adjusting blade)."
      • yellowghost
        142
        6
        Jun 6, 2010
        Canada
        Local Time:
        2:43 PM
        Made a few youtube movies today.
