DRENO
You have carbon under the valves ,
That's a big loss in compression all of a sudden don't you think? I can buy that being a problem but to happen just like that,well...
I have an old Toro 421 that was made in 1981. The thing is just plain awesome. I might actually buy a new spark plug for it this year...it still has the original. They don't make 'em as heavy duty anymore...mine has a steel chute and the same drive gear and belt sizes as todays 10hp models with 4hp.
Plus the Tecumseh 4hp engine will run on stale gas just fine too!
Typically if a snow blower doesn't start, it has water in the fuel bowl...pull it off, dump it out, and i bet it will start.
First thing I'd do Dreno is pull the plug and stick your finger over the hole and hit the starter or pull the rope. The compression should try to blow your finger off the hole. Another thing, is your spark should be a good blue color, if not pull the engine end cover (where the rope starter is) and there will be an ignition coil with .010" clearance to a magnetized portion of the flywheel. Also remove the 2 bolts that hold the coil to the engine block and make sure the ends of the bolt/spacer and side of the coil are clean and not rusted. A lousy ground will give a weak spark. I had this problem last week, lousy spark but I had gas and air wouldn't start. Now I got a blue spark and starts on the first pull. (Fried the starter last week, $225 for a new one, not a chance).
Try removing the sparkplug and splash a little gas in the cylinder . Reinstall plug and try to start. It should probably fire. If it does then get your choke set and try again. Also some machines wont start with throttle wide open --- try about 1/3 open. I have also forgot to open the gas valve at the fuel tank--it happens.
I have one in my garage,its orange and built by ariens, have not used it this season yet,crossing my fingers.
Windchill is -35 right now.8)
Sounds like a summer day in Winterpeg :toothy10:
Wylde1.
Sorry needsaresto,not trying to hijack your thread.8)
No worries. Try putting a shot of motor oil in the chamber. Crank it a couple times to spread the oil around and see if you can get a temporary seal. Then see if it will fire.
Here is some thing you can read until it warms up a bit DRENO
http://www.handymanwire.com/ubbthreads/showflat.php?Number=849837&page=0
