Today I got a Chrysler Parts book for 1965. Thick book, lot of parts, covers all Chrysler products. Very nice. Old and brittle, but a treasure to have. I bet a new production would not have these nice pictures either.
I enjoy reading about your progress.
There’s a lot of things to do but at the rate you’re going you’ll be driving it soon.
The trim around the headlights, the “candy canes”, are always dented & dinged; I hope you get yours to be presentable.
If there’s a Hobby Lobby nearby they may have some spray paint that might match and you could use it on the arm rest bases. Or an auto paint supplier might be able to mix you a good match.
This might help...
Paint Chips 1965 Chrysler Barracuda
Can't say if grain is exact, but it's certainly close enough. As for color - it is definitely close as well. there's no way to tell online. It's tough to compare even when you have 2 pieces side by side. Put it on. Nobody will know.Now, some say the vinyl above is not the same, different grain. But, tried to turn it a little around, and then it seems to match to me. Depending on where the light comes from it also changes a little in color.
I have no idea how long the vinyl have been in the car, if it changes any colorwise. The grain should not change.
Then my wife came home and has been moving it around this and that way and says they are the same, just depends on the direction and where you match them.
Can't say if grain is exact, but it's certainly close enough. As for color - it is definitely close as well. there's no way to tell online. It's tough to compare even when you have 2 pieces side by side. Put it on. Nobody will know.![]()
So I bought these. They work great and I got a bunch of them lol. You will need to get nuts but those can be had at any hardware storeI have not been able to find any screws and nuts for fastening the Candy canes and hood molding. Does anyone know where I can find that ? Does not have to be NOS, but have to fit and work and be new.
Yes it is. Tabs look like they are broke off thou.I have not cleaned mine up yet, but I suspect it is the same ones as yours.
