The water pump was not in good shape, I plan on replacing the water pump and the oil pump. All the freeze plug are brass and look good on the inside. I can see down the water jackets now that I have the water pump off. All gaskets will be replaced including the rear seal. The timing set on the motor looks like it may have been replaced at some point. It's coming a long. Right now I am cleaning and sanding the manifolds to get them ready for high heat painting.
I don't see how you could use that cable-shift tranny (65-) in a 1968 car. The only easy way would be to install a 65- floor shifter, which would take a bit of work (need bracket off trans tunnel and holes going forward), plus those shifters are rare and may not look right in your car. Better to sell the tranny to someone who needs it, but they would need to know if 65 or 64- because I am pretty sure the valve body differed. At a minimum, salvage the shift and park cables and attachments because someone needs those, and they are cheap to ship. The valve body is valuable also.Should I use the tranny that is attached to this motor ... ?
