1. jonn6464
    jonn6464 1970 Duster FABO Gold Member
    877
    861
    Mar 29, 2017
    Weatherford, TX
    Local Time:
    8:57 AM
    Anybody know what this bolt is for?
    It was in the bag with bolts and parts from when I removed my steering column.
    I can't find anything that looks like it in the exploded view in the FSM. It says MF on the head.
    Thank you.
  2. Princess Valiant
    Princess Valiant Duster specialist
    24,755
    19099
    Dec 14, 2011
    Colorado
    Local Time:
    7:57 AM
    Steering column bolt
    The steering column mounts at 3 points under the dash frame. The two closer to the driver are nuts with that same washer, and the 3rd point is that bolt and washer.
    They are very specific to the steering column
    • Agree Agree x 4
    • Like Like x 2
    • Thanks! Thanks! x 1
    • Dragonsteel
      Dragonsteel Well-Known Member
      268
      301
      May 12, 2015
      Missouri
      Local Time:
      8:57 AM
      Looks like a steering column bolt that hold the column up to the dash, the front two are nuts, but the back one is a bolt.
      • Agree Agree x 1
      • Princess Valiant
        24,755
        19099
        Dec 14, 2011
        Colorado
        Local Time:
        7:57 AM
        The nuts are also very specific
        • Like Like x 3
        • Agree Agree x 1
        • RedFish
          RedFish Well-Known Member
          25,027
          3721
          Sep 5, 2007
          Local Time:
          9:57 AM
          Agree with above comments. That bolt goes into a caged nut. DO NOT cross thread that fecker. I wont ever carry my air ratchet under there again. Point and shoot ruined my day.
          • jonn6464
            877
            861
            Mar 29, 2017
            Weatherford, TX
            Local Time:
            8:57 AM
            Ah, I see. So, the front 2 mounting points are on the studs and the bolt goes in the mount closest to the firewall.
            Thanks for the reply.
          • RedFish
            25,027
            3721
            Sep 5, 2007
            Local Time:
            9:57 AM
            Yep, and one of the 2 studs gets a ring terminal from a little ground jumper wire with additional nut on top.
            • Agree Agree x 1
            • krazykuda
              krazykuda Well-Known Member FABO Gold Member How-To Section Editor
              60,427
              26590
              Aug 20, 2007
              Orland Park, IL
              Local Time:
              8:57 AM
              • jonn6464
                877
                861
                Mar 29, 2017
                Weatherford, TX
                Local Time:
                8:57 AM
                Where does the other end of that ground jumper wire go? Steering column jacket?
              • Jim Lusk
                Jim Lusk Well-Known Member
                5,285
                1705
                Mar 8, 2006
                Fresno, CA
                Local Time:
                6:57 AM
                Yes.
