1. nodemon
    nodemon Well-Known Member
    409
    116
    Mar 21, 2015
    St.Louis
    Local Time:
    7:11 PM
    Can anyone identify this cam and decode the numbers.. There was no info with it when I picked it up. 0410210000.jpg
    • Like Like x 1
    • Demonracer
      Demonracer 71 Demon 00 Ram 16 Chrysler 300S 05 Caravan FABO Gold Member
      5,201
      3232
      Jan 31, 2010
      Cleveland, Texas
      Local Time:
      7:11 PM
      Call Isky cams & give them the numbers, that's what I'd do.
      • Agree Agree x 4
      • 12many
        12many Well-Known Member
        2,103
        2526
        Dec 14, 2016
        South Car
        Local Time:
        7:11 PM
        It’s on a 108 LSA, not sure that the other stampings will tell much, what is the etched number sequence?
      • 65Val
        65Val Average Length Member
        5,297
        1248
        Oct 14, 2005
        Victoria, BC, Canada, EH!
        Local Time:
        5:11 PM
      • Bewy
        Bewy Well-Known Member
        944
        569
        Jan 1, 2021
        Australia
        Local Time:
        10:11 AM
        It is most likely the B777 grind. It is a sol, not hyd cam. I have used a couple in 440s & they were a great street/performance cam. It was so good that I had a local cam grinder make a copy of it. 280* adv duration, 240 @ 050, 108 LSA, 0.480" valve lift.
        It had 268* @ 0.020". Comp & other companies often quote their adv durations for sol cams at 0.020" tappet rise. Try finding another cam of around this duration that has just 28* of separation between 020 & 050...& had it in the 1970s. I have a bit of a smile when i hear about all these 'new' short timing cams.
        • Like Like x 2
        • George Jets
          George Jets 1967 Dart 2 Door FABO Gold Member
          5,281
          7290
          Jan 18, 2019
          Farmington MN
          Local Time:
          7:11 PM
          Isky D888
          • Disagree Disagree x 1
          • 65Val
            5,297
            1248
            Oct 14, 2005
            Local Time:
            5:11 PM
            Here’s more...
            • Like Like x 1
            • Agree Agree x 1
            • Bighead440
              Bighead440 Well-Known Member
              368
              288
              Jun 18, 2017
              Milledgeville, Georgia
              Local Time:
              8:11 PM
              It's a Poly cam, that's what the "277" means (Plymouth baby sister to the 318A). I had a NOS one and sold it to a guy with a '64 Poly and he loved it!! Sent me a video with sound and it loped pretty good, and he said it needs a tad more stall, like maybe a factory 11" hi-stall truck converter with the earlier input splines. Won't work in a LA motor, due to lobe sequence. The cam card above^ shows the same lift and duration specs but a different lobe separation than the one I sold. My timing events were 35-71,71-35 and part number 150188, grind #D-888.
              • Like Like x 2
              • 65Val
                5,297
                1248
                Oct 14, 2005
                Local Time:
                5:11 PM
                :popcorn:Its definitely 1 of 5 cams mentioned here...OP, any closer to ID’ing it correctly? :drama:
                • Like Like x 1
                • Thanks! Thanks! x 1
                • nodemon
                  409
                  116
                  Mar 21, 2015
                  St.Louis
                  Local Time:
                  7:11 PM
                  LOL.... Nope...! I was given this cam by someone that " knew what they were talking about"... He said it would be PERFECT for my stock, 72 318 manual 3 spd... 8 3/4 3.23
                  I sent an email to Isky to see if they can give me some definitive info.
                  • 65Val
                    5,297
                    1248
                    Oct 14, 2005
                    Local Time:
                    5:11 PM
                    PUULLEEZZE come back and tell us what it is!... curiosity is killing me!:steering::steering:
                    • Like Like x 2
                    • George Jets
                      5,281
                      7290
                      Jan 18, 2019
                      Farmington MN
                      Local Time:
                      7:11 PM
                      Must be the Mopar 340 cam in an Isky Grind.
                      Lift: 430/444
                      Duration: 268°/276°
                      112 lobe centers
                      Good ^^^^^ Baseline to start with for a 318.
                      • Bighead440
                        368
                        288
                        Jun 18, 2017
                        Local Time:
                        8:11 PM
                        LOL. I posted what it is earlier, I just sold one identical to it last year. Lay it next to a LA/SBM cam and marvel a how the lobes are not arranged in the same way. It's not going to run in ANY 318 but a Polysphere. Look up the part number I listed above in an old Isky catalog (from the 1970s, maybe early '80s), that's what I did to identify the one I had.
                      • 65Val
                        5,297
                        1248
                        Oct 14, 2005
                        Local Time:
                        5:11 PM
                      • nodemon
                        409
                        116
                        Mar 21, 2015
                        St.Louis
                        Local Time:
                        7:11 PM
                        Is it worth anything..?? If it won't work in my 318, I'll just sell it.
                        • Agree Agree x 1
                        • Bighead440
                          368
                          288
                          Jun 18, 2017
                          Local Time:
                          8:11 PM
                          They fellow who bought mine loved it. I got it in a pile of Isky parts and I kept what I could use, but I had no Poly/A-motors. Somebody on FBBO or the HAMB etc. would love to have it I'm sure. Compare it to a LA cam and let us know, I don't want to lead you astray. If it is for a LA engine it would probably work good on the street, but I think that "277" is the damning marking!
                        • RustyRatRod
                          RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
                          77,085
                          54071
                          Jun 7, 2010
                          Georgia
                          Local Time:
                          8:11 PM
                          Now you are beginning to see my frustration. ;)
                          • Agree Agree x 1
                          • RustyRatRod
                            77,085
                            54071
                            Jun 7, 2010
                            Georgia
                            Local Time:
                            8:11 PM
                          • RustyRatRod
                            77,085
                            54071
                            Jun 7, 2010
                            Georgia
                            Local Time:
                            8:11 PM
                            Right.....if I'm reading all this right, the "D888" is the grind number, right? While the "277" is the specific type core. In other words, the "D888" could be the same grind for most any make across the board, while the "277" tells us it's for the Poly engine, Correct?
                            • Agree Agree x 1
                            • Bewy
                              944
                              569
                              Jan 1, 2021
                              Australia
                              Local Time:
                              10:11 AM
                              Lobe lift is easy to measure. Measure LL & that will narrow the possibilities.
                            • nodemon
                              409
                              116
                              Mar 21, 2015
                              St.Louis
                              Local Time:
                              7:11 PM
                              Thanks for that... I will post what I find out from Isky.
                              • Agree Agree x 1
                              • Bighead440
                                368
                                288
                                Jun 18, 2017
                                Local Time:
                                8:11 PM
                                I found the picture of the cam I sold, now running in a Poly.
                              • nodemon
                                409
                                116
                                Mar 21, 2015
                                St.Louis
                                Local Time:
                                7:11 PM
                                Spoke with Richard Isky today... He thinks, based on the info I gave him, that the cam I have is an old one..60's or earlier... He said perhaps for a 331 Hemi.. I'm emailing some pix and measurements he requested...and he said he might be able to tell me more about it.
                                • Agree Agree x 1
                                • nodemon
                                  409
                                  116
                                  Mar 21, 2015
                                  St.Louis
                                  Local Time:
                                  7:11 PM
                                  • Agree Agree x 1
                                  • nodemon
                                    409
                                    116
                                    Mar 21, 2015
                                    St.Louis
                                    Local Time:
                                    7:11 PM
                                    • Like Like x 1
