Mystery clips from doors '65 Barracuda
Bob Jasinski
Danville CA
Assembling my door locks and window regulators. Parts were bagged in 2009, I can find a home for everything but these two clips. I think they are for the lock to key linkage, but I have it all together without these and it seems to work just fine. They also seem to fit a larger diameter wire than what is used on the lock linkage. I have two (one for each door I assume). Where do these go?
So, since this thread is about window regulator parts, anyone have a source for these bushings? Mine's got a broken tooth. It goes right under the clip in post #1. Its for the pin in the forward arm of the front regulator.
