superbyrd
explorer 8.8 rear end. factory disc brake, 4.10 gear ratio with trac-loc posi. 31 spline axles. has had the drivers side tube narrowed 3 inches, new axle shaft. has new spring perches welded on at 43 inch centers for A-body. axle is 57.250 wheel mounting surface to wheel mounting surface. comes with rotors, calipers, pads, backing plates ,the yoke to change the end of your driveshaft, and a new chrome rear cover with bolts. open for inspection. price is $400 obo. i am in henderson,ky 42420
thanks
thanks
