Narrowed Down to 2 Cams
Small Block Mopar Engine
  1. thedartsport
    thedartsport Well-Known Member
    312
    161
    Nov 24, 2010
    Tennessee
    Local Time:
    11:18 PM
    So I've narrowed my choices down to two cams and was hoping some of you could help me decide.
    The car is a 1972 Dart Swinger
    Full interior
    Stock 360 w/ 4 barrel and eventually headers
    Will do mild port work to the factory heads
    904 with stock stall and rebuilt lockup converter (was told it was around 2000)
    Will have an 8.75 with 3.23 SG (maybe 3.55)
    245/60/15 rear tires
    This car will mainly be street driven, but I'd like to run the 1/8th mile at the local track if I ever felt like it every now and then. Hopefully either of these will spin the tires.
    Which cam fits? I'll get valve springs that either cam calls for.
    Summit 1789
    Summit RacingĀ® Cam Kits SUM-K50052
    Comp XE-262H
    COMP Cams Xtreme Energy Cam and Lifter Kits CL20-222-3
  2. aaronk785
    aaronk785 Well-Known Member
    804
    613
    Apr 21, 2013
    westmoreland ks.
    Local Time:
    11:18 PM
    Use the comp cam. I cant remember what mag it was, but they made that exact build minus the head porting and made 300 hp. Should be a great street engine and run on 87 fuel.
  3. Krooser
    Krooser Building Chinese Free Engines since 1959...
    3,360
    2937
    Jul 19, 2015
    Central Wisconsin
    Local Time:
    11:18 PM
    Neither... both of those cams are ground for a Chevy diameter lifter.
    Find a cam that's ground for a .904 lifter. I go to www.jonescams.com or try Howards. Jones will cost you more but give you more smiles per mile. You may have to have a custom grind... yes it makes a difference.
    • Like Like x 3
    • yellow rose
      yellow rose Overnight Sensation
      28,501
      25174
      Jun 19, 2015
      Central Washington
      Local Time:
      9:18 PM
      Or call Jim at Racer Brown.
      Or Cam Motion.
      Both do .904 lifter specific grinds.
      If you don't correct geometry you lose most of what you gain with the .904 lobe.
    • Krooser
      3,360
      2937
      Jul 19, 2015
      Central Wisconsin
      Local Time:
      11:18 PM
    • BoogieMan67
      BoogieMan67 FABO Gold Member FABO Gold Member
      316
      151
      Dec 24, 2016
      Tennessee
      Local Time:
      11:18 PM
      Put you a 68 340 four speed cam in it.
    • nm9stheham
      nm9stheham Well-Known Member
      12,089
      3979
      Dec 20, 2013
      Waynesboro, VA
      Local Time:
      12:18 AM
      Mixed reaction..... Maybe a bit more torque with the Comp.... a modest improvement for tire spinning with the Sure Grip and general street driving. The Summit's slower ramps will be easier on the valve train.
    • Krooser
      3,360
      2937
      Jul 19, 2015
      Central Wisconsin
      Local Time:
      11:18 PM
      I visited my buddy last night who has a fresh BB and SB in stock each waiting for a home.
      The 340 has a cam ground by Erson that was a custom grind set-up by his engine guy. About 487 lift/228 duration on a 106 lsa.... damn near the specs of my kids dirt b-mod motor. The HP program he uses says it will be around 480 HP at 6500 rpm's... should be a real neck snapper as it comes in around 4000... it's also a .904 grind.
    • mod5v
      mod5v Well-Known Member
      652
      134
      Feb 17, 2006
      fortworth
      Local Time:
      11:18 PM
      If your looking for a low cost bigger than stock cam go with the Summit. BUT like the others said neither cam is really optimum for what you are doing. I would wait until you have the short block done so you can measure how far in the hole the pistons are and them have a grinder pick you out a cam after you fill out their on line questionnaire. Howards and bullet both come to mind but there are a few others that do a great job also.
    • toolmanmike
      toolmanmike Moderator Staff Member FABO Gold Member
      62,400
      51606
      Jan 18, 2006
      Iowa
      Local Time:
      11:18 PM
      Another vote for calling the cam company.
    • scatpackbee
      scatpackbee Well-Known Member
      744
      510
      Feb 10, 2007
      Georgetown, Ontario
      Local Time:
      12:18 AM
      Where do you get one of those?
    • toolmanmike
      62,400
      51606
      Jan 18, 2006
      Iowa
      Local Time:
      11:18 PM
      A couple guys on here were working on the grind. No one has replicated the 340-4 speed cam.
    • rumblefish360
      rumblefish360 I have escaped the evil Empire State! FABO Gold Member
      41,701
      13951
      Jun 21, 2005
      Florida
      Local Time:
      12:18 AM
      Between the 2 choices, the Comp cam.
      IMO, your not going to see a lot with a custom ground cam for the diameter of the larger tappet. It will be there and measurable on the dyno, but not with the butt dyno.
      Your call.
      • Agree Agree x 1
      • dogbreath
        dogbreath Well-Known Member
        385
        158
        Nov 29, 2009
        Local Time:
        11:18 PM
        The 262 is to small , step up to the 268 you will be happy.
        • Agree Agree x 1
        • toolmanmike
          62,400
          51606
          Jan 18, 2006
          Iowa
          Local Time:
          11:18 PM
          That's not one of the choices though. (although a better choice for a 360) :poke::poke:
        • thedartsport
          312
          161
          Nov 24, 2010
          Tennessee
          Local Time:
          11:18 PM
          I've just read of people on here having trouble bogging off the line with the 268 and a stock stall. That's why I chose the 262.
        • Lelo Dart
          Lelo Dart * FABO Gold Member
          1,494
          441
          Oct 10, 2012
          Knob Noster MO.
          Local Time:
          11:18 PM
          I vote comp 262. I don't know about bogging with the XE268, sounds like a tuning problem.
          • Like Like x 1
          • RustyRatRod
            RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
            79,449
            57887
            Jun 7, 2010
            Georgia
            Local Time:
            12:18 AM
            Either is fine for what you plan to do. Flip a coin.
          • aaronk785
            804
            613
            Apr 21, 2013
            westmoreland ks.
            Local Time:
            11:18 PM
            If its a stock 360 compression is about 8 to 1. I would guess the 262 would be better for that compression.
            • Agree Agree x 1
            • 273
              273 Well-Known Member
              3,781
              1526
              May 14, 2012
              Ontario
              Local Time:
              12:18 AM
              I'd go 262 cause thr factory heads need a little help on the exhaust.
              • Agree Agree x 1
              • AJ/FormS
                AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
                21,770
                9021
                Jan 19, 2014
                South-Central Manitoba,Canada, 900ftelevation
                Local Time:
                11:18 PM
                The Summit will steal your low-rpm torque, and throw it right out the tailpipes.
                With a low-compression engine, you can't afford those Summit ramps.
                Here's your Summit,272/110,216@.050
                Static compression ratio of 8:1.
                ICA of 62*
                Effective stroke is 2.84 inches.
                Your dynamic compression ratio is 6.55:1 .
                Your dynamic cranking pressure is 122.91 PSI.
                V/P (Volume to Pressure Index) is 105..........................................................105
                Heres the Comp,262/270/110,218/224@.050
                Static compression ratio of 8.0:1.
                ICA of 57*
                Effective stroke is 2.95 inches.
                Your dynamic compression ratio is 6.77:1 .
                Your dynamic cranking pressure is 128.43 PSI.
                V/P (Volume to Pressure Index) is 114.........................................................114
                The comp is 114/105=8.6% stronger from idle to somewhere around 3500. That's a lot! The com is also more flexible in the installed centerline, and to top it off it has more .050 duration and a tad more lift, which on the exhaust side will help those stock iron heads breath. With a2000 TC and 3.23s, only the Comp stands a chance of spinning both tires. 114VP is the same as a stock 318LA. A VP of 105 is pretty sucked out, that's about where a stock slanty is at
                For comparison, here's the factory stock 360, with the 252/112 cam
                ICA of 54*
                Effective stroke is 3.02 inches.
                Your dynamic compression ratio is 6.91:1 .
                Your dynamic cranking pressure is 131.95 PSI.
                V/P (Volume to Pressure Index) is 120........................................................120
                Read about VP here;
                V/P Index Calculation
                The .050 numbers give you a pretty good idea of how to compare cams hence it was said "flip a coin".
                The advertised numbers give an idea of what the idle will sound like,lol, and maybe how hard the cam might be on the valve-train, as was also mentioned.
                The difference between the two gives a idea of how much compression will be lost in the initial take up of the acceleration ramps.And that's the point I'm trying to make.
                To bring the Summit cam up to speed, you would have to raise the compression to
                Static compression ratio of 8.5:1.
                ICA of 62*
                Your dynamic compression ratio is 6.95:1 .
                Your dynamic cranking pressure is 132.97 PSI.
                V/P (Volume to Pressure Index) is 114........................................................114
                Now you can enjoy the same114VP, with a tad less duration at .050 and a tad less lift, but with a bit of a lope in the idle, that the Comp won't have.
