necking down after collecter?
Mopar Exhaust Systems
  1. 70DusterBob
    70DusterBob Well-Known Member
    567
    126
    Feb 20, 2016
    Texas
    Local Time:
    4:27 AM
    The shop my Duster is in wants to neck down the exhaust from TCI headers to a 2 inch pipe. The collectors are 3", after the foot of 2" pipe they plan to use, the 2" extensions the headers came with, they plan on going to 3" out the back. Is this stupid or a good idea?
    Thanks
  2. MOPAROFFICIAL
    MOPAROFFICIAL FABO Gold Member FABO Gold Member
    5,480
    4459
    Jun 1, 2016
    Beach
    Local Time:
    2:27 AM
    What cid and cam duration?
    I can about guarantee it's a stupid idea.
    • Agree Agree x 6
    • Treblig
      Treblig Well-Known Member
      5,930
      3151
      Oct 5, 2013
      South Texas
      Local Time:
      4:27 AM
      One muffler shop dude told me (and it made sense) that the exhaust is hot near the headers and cools as it travels out the back. That's why you can hold your hand over the rear exhaust pipe but not at the header outlet (too hot). Cooling gas should condense.....so the same amount of exhaust gas (volume) at the header should decrease in volume by the amount that it cools (temp) off as it travels to the rear.
    • 70DusterBob
      567
      126
      Feb 20, 2016
      Texas
      Local Time:
      4:27 AM
      It is a BPE 408 with the following specs:
      · HP & Torque: 445 HP / 500 FT LBS
      Compression Ratio: 10.1:1
      Aluminum Heads
      Flat Tappet Cam
      Cast Steel Crank
      Forged Pistons
      Block:
      · Hand picked seasoned block
      Square and parallel decked
      Align honed main bearing bore
      Cylinders honed on computer controlled machine to within .0002 straightness and roundness
      Cylinders are sonic tested for thickness
      2-Bolt Main
      4.000" Bored .040" over
      2-Piece Rear Main Seal
      Mech fuel pump provision: Yes
      Rotating Assembly:
      · New Cast steel crankshaft
      4.000" Stroke
      OEM type 6.123" connecting rods w/ 150,000 psi bolts
      Forged pistons
      External
      Cylinder Heads:
      · Aluminum Cylinder Heads - 63cc chamber
      2.02" intake/1.60" exhaust valves
      171cc intake/77cc exhaust runners
      Cam Specs:
      · Cam Type: Flat Tappet
      .545 Intake .545 Exhaust
      241 Intake / 247 Exhaust duration
      @ .050 - 110 degree lobe separation
      Ignition Timing:
      · 34 degrees total at 2500-3000 RPM
    • RustyRatRod
      RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
      60,035
      31176
      Jun 7, 2010
      Georgia
      Local Time:
      5:27 AM
      Dumbest crap I ever read. 3" all the way.
      • Agree Agree x 8
      • Like Like x 1
      • MOPAROFFICIAL
        5,480
        4459
        Jun 1, 2016
        Beach
        Local Time:
        2:27 AM
        You're referring to what's called "tuned exhaust".... what you do.. is... you take shoe polish, and you wipe a fkn line every 8 inches from the collector on the extension.... or about 3 line...the last line of shoe polish that burns off.... is where you would attach the muffler....imo that has NOTHING to do with the diameter required...smaller would probably move that line further down the pipe even..'more heat'. Need to know what you're doing and not let some Ck biter steer you queer.
        • Like Like x 2
        • 70DusterBob
          567
          126
          Feb 20, 2016
          Texas
          Local Time:
          4:27 AM
          He was mentioning something like that, that the neck down needed to be where the paint no longer burned off the exhaust was his explanation. You did a much better job of it. I'm just concerned that it is not far enough back and too narrow. I posted the specs above for the engine. I have 3 step headers on it: 1-5/8 to 1-3/4 to 1-7/8 into a 3" collector.
        • Phreakish
          Phreakish Well-Known Member
          707
          353
          May 28, 2015
          N. Idaho
          Local Time:
          2:27 AM
          Do you really mean they want to go straight to 2" and then later bump it back to 3"??
          Stupid.
          Except for maybe using a choke at or in the collector, the exhaust should continue at collector diameter for some length and terminate into very large volume in order to take advantage of any wave tuning the extension might help create.
          This is a good article.
          • Agree Agree x 2
          • MOPAROFFICIAL
            5,480
            4459
            Jun 1, 2016
            Beach
            Local Time:
            2:27 AM
            Re cam that pos too.
            The heads on it, should make 500
          • Scamp Rohnda
            Scamp Rohnda Well-Known Member
            361
            310
            Jan 18, 2017
            Blaine MN
            Local Time:
            4:27 AM
            Check with Johnny Mac and Blue Point, I'll bet they have your answer.
            • Agree Agree x 1
            • rumblefish360
              rumblefish360 So close, yet so far away FABO Gold Member
              37,822
              9515
              Jun 21, 2005
              New York, on a Island
              Local Time:
              5:27 AM
              Quick! Run away, very quickly. Run your ass off. There secretly anti MoPar as well as plain old fashion stupid.
              • Agree Agree x 3
              • Like Like x 1
              • 70DusterBob
                567
                126
                Feb 20, 2016
                Texas
                Local Time:
                4:27 AM
                Sounded like crap to me too. I'm looking for 3" extension/collectors, Summit does not have a 3" in 3" out. Not that I can find.
              • 70DusterBob
                567
                126
                Feb 20, 2016
                Texas
                Local Time:
                4:27 AM
                LOL, I hear ya.
              • 70DusterBob
                567
                126
                Feb 20, 2016
                Texas
                Local Time:
                4:27 AM
                Gotcha
              • rumblefish360
                37,822
                9515
                Jun 21, 2005
                Local Time:
                5:27 AM
                Favorite post and best next move after you run Away from that asshole lead exhaust shop that contains morons and asshats inside out being worn upside down.
                Smartest post yet. Possibly better yet, get the book by David Vizard.
                • Like Like x 2
                • Thanks! Thanks! x 1
                • thesiren74
                  thesiren74 Well-Known Member
                  1,200
                  749
                  Feb 23, 2014
                  kenosha,wi
                  Local Time:
                  4:27 AM
                  2 1/2" minimum, 2" is for a stock 318
                  • Agree Agree x 5
                  • rumblefish360
                    37,822
                    9515
                    Jun 21, 2005
                    Local Time:
                    5:27 AM
                    Go to Jegs
                    • Agree Agree x 2
                    • Like Like x 1
                    • Phreakish
                      707
                      353
                      May 28, 2015
                      N. Idaho
                      Local Time:
                      2:27 AM
                      Like this?
                      You can also get 3" "reducers" made for a 3" collector that are made to weld the rest of your exhaust to. Either way works. The torsion bar cross member is typically pretty close though... So the longer extensions may be more trouble.
                      • Like Like x 1
                      • rumblefish360
                        37,822
                        9515
                        Jun 21, 2005
                        Local Time:
                        5:27 AM
                        I don’t even think the stock 318 ever cam with a 2 inch exhaust. IIRC (LMAO @ that but....) stock exhaust tubing is 1-7/8. Correct?
                        • Agree Agree x 3
                        • Phreakish
                          707
                          353
                          May 28, 2015
                          N. Idaho
                          Local Time:
                          2:27 AM
                        • thesiren74
                          1,200
                          749
                          Feb 23, 2014
                          kenosha,wi
                          Local Time:
                          4:27 AM
                          It was an example.
                        • rumblefish360
                          37,822
                          9515
                          Jun 21, 2005
                          Local Time:
                          5:27 AM
                          Gotcha!!!
                          • Like Like x 1
                          • Treblig
                            5,930
                            3151
                            Oct 5, 2013
                            South Texas
                            Local Time:
                            4:27 AM
                            • Agree Agree x 1
                            • 70DusterBob
                              567
                              126
                              Feb 20, 2016
                              Texas
                              Local Time:
                              4:27 AM
                              • Like Like x 1
                              • 70DusterBob
                                567
                                126
                                Feb 20, 2016
                                Texas
                                Local Time:
                                4:27 AM
                                They are TCI headers if I remember correctly. The pipes going into the collector are huge, 2" is barely half the size. I'm like?????
