bbrroowwnn
never re member
Looking for a factory style very short mopar throttle cable.....Needs to be in the 12 to 14 inch range....Don't care what it is off of as long is it is the right length....square or round end through firewall does not matter because I have to cut hole anyway.....I have a 24 inch and a 19 inch and they are too long....I Have a lokar cut to fit setup but you have to use their bracket which don't work on TQ's and their ends of the cable don't work with my factory carb stud and factory kickdown linkage & pedal....And everything else is perfect and works flawlessly so if I can just find a shorter factory cable, I will be in business.....
