I bought all my stuff from Cass at Dr. Diff. here's a cut/paste from my order. I forgot to get pictures and I am not up for going out and getting them now, dealing with a sick son. I'll try to snap the pics tomorrow.
Product Price Quantity Subtotal
1 Piece Distribution Block
Options:Car: All Others;
$85.00 1 $85.00
10.7" Rear Disc Brake Kit
Options:Caliper Color: Black; Add Rear Disc Brake Lug Studs: No; Upgrade to Drilled/Slotted/Plated Rotors: No; Add Custom Parking Brake Cables: Yes (+$100.00); Year and Make of Car: 68 barracuda;
$700.00 1 $700.00
Front Brake Line Selector
Options:Model Year: 1968; Platform: A-Body; Model: Barracuda/Cuda; Master Cylinder: Standard Power Booster; Front Brakes: OEM 4 Piston Calipers; Firewall Line Position: Right firewall line run under frame rail; Caliper Position: Rear; Choose Brake Lines: Complete Front Hard Line Package (+$59.00); Add Flex Hoses: Short Rubber (+$35.00);
$94.00 1 $94.00
Front to Rear Brake Line Selector
Options:Model Year: 1968; Platform: A-Body; Model: Barracuda/Cuda; Front Brakes: OEM 4 Piston Calipers; Body Style: 2 Doors; Rear Brakes: DoctorDiff 10.7" Disc; Brake Valve: Re-use Existing Dist. Block for 4 wheel drum or 4 wheel disc; Choose Brake Line Material: Original (+$50.00);
$50.00 1 $50.00
Rear Axle Brake Line Selector
Options:Model Year: 1968; Platform: A-Body; Model: Barracuda/Cuda; Rear End: Dana 60; Rear End Width: 57 1 /2"; Vent Bolt Location: 11 1/4" from Center of Housing; Rear Brakes: DoctorDiff 10.7" Disc (lines come semi-pre-bent); Choose Brake Line Material: Original Material (+$25.00); Add Rearend to Body Flex Hose: DOT Stainless (screw-in type) (+$50.00); Add Brass Tee: Yes (+$15.00); Add Vent-Bolt: Yes (+$15.00);
