Need D.S. 273 manifold or substitute
Discussion in 'Early A-Body Discussions' started by mycuda, Jun 12, 2018.
  1. mycuda
    mycuda FABO Gold Member FABO Gold Member
    4,845
    1691
    Feb 15, 2011
    Chicago/ Metro
    View My Photos
    Local Time:
    3:34 PM
    Got motor trans in today,not easy. Steering link hitting 360 LA oil pan slightly???
    Could ding oil pan slightly??
    Had engine 4spd trans 12 feet off ground pulling trans tail down with rope to eventually get in...WHEEEEh
    Thanks, Dave
    • Like Like x 4
    • B-onefan
      B-onefan Well-Known Member
      1,241
      65
      Oct 2, 2009
      Texas
      Local Time:
      3:34 PM
    • Valiant63
      Valiant63 Early A-body Valiants
      1,206
      183
      Dec 29, 2007
      eastern, PA and central Florida
      Local Time:
      3:34 PM
      Yes, ding the oil pan for clearance, but don't use a metal Hammer, use a mallet or put a piece of wood against the pan and hit it with a metal hammer. You don't want to crack or put a hole in your oil pan.
      Also, I have a couple of driver side exhaust manifolds for the early a bodies. On other cars I have had I have match ported them and smooth them out and they seem to run pretty good.
      • Agree Agree x 1
      • Kern Dog
        Kern Dog Well-Known Member
        2,282
        1476
        May 23, 2010
        Granite bay CA
        Local Time:
        1:34 PM
        OP, this question is the key.
        Slant six cars had a center steering link that had a shallow "drop" in the middle since the 170 and 225 Slanty had a shallow oil pan. V8 oil pans are deeper and because of this, in 1964, they had a different center link for V8 cars. It dips further down and allows plenty of clearance for the V8 pan.
        • Agree Agree x 1
        • mycuda
          4,845
          1691
          Feb 15, 2011
          Chicago/ Metro
          View My Photos
          Local Time:
          3:34 PM
          Ok, was told /6 links the same? Guess not. It is on 69 Dart I swapped.
          Thanks, Dave
        • vitamindart
          vitamindart Well-Known Member
          945
          87
          Jun 11, 2010
          Vernon,Wisconsin
          Local Time:
          3:34 PM
          v8 link has more drop as said earlier, on my magnum I massaged a set of the magnum manifolds and ran a shim under the mounts to gain steering coupler clearance.
          • Like Like x 1
          • Thanks! Thanks! x 1
          • 65ChargerDart
            65ChargerDart 65ChargerDart FABO Gold Member
            190
            33
            Jun 25, 2005
            Fortson, GA
            View My Photos
            Local Time:
            4:34 PM
          • 65Val
            65Val Average Length Member
            4,534
            583
            Oct 14, 2005
            Victoria, BC, Canada, EH!
            View My Photos
            Local Time:
            1:34 PM
            Yes...'66-down have different center links...slant 6 or V8
            • Agree Agree x 1
            • pishta
              pishta I know I'm right....
              11,946
              2145
              Oct 13, 2004
              Tustin, CA
              View My Photos
              Local Time:
              1:34 PM
              Shoot us a pic! Magnums in a early A are long in word, short in pics. Biggest gripe is the steering clearance and I want to see how you addressed this. I have also shimmed a steering box (and I slotted the mounting holes) to fit a 400 based 451 in a 65 A with Hi-po logs.
              • Like Like x 1
              • Kern Dog
                2,282
                1476
                May 23, 2010
                Granite bay CA
                Local Time:
                1:34 PM
                How are those different from the standard 273 manifolds?
                Regarding the steering: In 1967, the K member, tie rods and center link were redesigned. The center link cleared all factory engines from then until the end of production in 1976.
                Lots of development through the long run of the A-Body steering, brakes and suspension.
              • 65Val
                4,534
                583
                Oct 14, 2005
                View My Photos
                Local Time:
                1:34 PM
                It's not whether the ex. mans. are from a 4bbl or 2bbl (BTW, they are the same), it's whether they are 1st gen (pre '66) or 2nd gen and up ('67 and on)...those 2 are different.
                • Agree Agree x 1
                • Kern Dog
                  2,282
                  1476
                  May 23, 2010
                  Granite bay CA
                  Local Time:
                  1:34 PM
                  Thanks, my point was that I didn't think that there were any "4 barrel" 273 exhaust manifolds. I figured that they used the same ones on all 273 engines 64-66 and a different style 67-69.
                  • Like Like x 1
                  • Agree Agree x 1
                  • 65Val
                    4,534
                    583
                    Oct 14, 2005
                    View My Photos
                    Local Time:
                    1:34 PM
                    Totally correct!:thumbsup:
                    • vitamindart
                      945
                      87
                      Jun 11, 2010
                      Vernon,Wisconsin
                      Local Time:
                      3:34 PM
                      I will see if I can dig up some pictures, I have since swapped it out with a slant 6
                    • pishta
                      11,946
                      2145
                      Oct 13, 2004
                      Tustin, CA
                      View My Photos
                      Local Time:
                      1:34 PM
                      The magnums extend pretty far back on the passenger side and go about straight down on the driver side but dont hit the starter? They are supposed to flow right up there with the 68 340 logs for 10% of the cost. There are 2 sizes: the early year 618-619 casting had a 1/8 larger outlet. Cap that EGR fitting. Plenty of room for a standard oil filter!
