Need help identifying bad IVR
Electrical and Ignition
  1. Chained_360
    Chained_360 FABO Gold Member FABO Gold Member
    390
    107
    Nov 11, 2015
    Anchorage, Alaska
    Local Time:
    8:35 PM
    Howdy all, I need some help tracking down why my gauge cluster is acting funny. I'm curious if it's the IVR, because the problem itself is a bit of a doozy.
    It's a long story, so here is the short of it. My 68 notchback (360/904) has been running 'hot' for the past month and a half, but it has never actually overheated. The temp needle loves to stay in the upper quarter of the gauge, sometimes pegging if you turn the car on after it is warm. Sometimes it settles down in the normal range, sometimes it doesn't. But regardless of what the gauge reads, the car has never had an actual meltdown (shutting off, spewing coolant, etc.). I'm trying to find out why.
    The water pump was replaced two and a half years ago (admittedly with an el-cheapo unit), and the only mods to the cooling system is the flex-a-lite fan and absence of a shroud. The belt has enough tension and isn't slipping. Last summer, the car would do a strange thing where it would peg the gauge when It warmed up and then settle down in the normal range.
    Today, as I was trying to pinpoint if it would ''overheat" at cruise or idle, the factory oil pressure gauge started to move around erratically, which caused me to scratch my head, as the factory oil pressure gauge has never read anything since I bought the car. This is because the previous owner installed a mechanical oil pressure gauge under the dash.
    As for the fuel gauge, it never worked when I bought the car, and when I replaced the tank and sender, I never hooked it back up due to the reproduction sender stud not being long enough. I tried connecting it with alligator clips and whatnot, and couldn't get the gauge to read anything.
    Apologies for the shaky/incomplete information, this temp gauge issue has plagued the car since I bought it and I wanted to give the full scoop. I know a bad IVR will knock out the oil, temp, and gas gauges, but I don't know if a failing one would cause the cluster to act like this, because the way the car is now leaves the possibility that all three gauge issues are completely separate and just happen to be rearing their heads at the same time. The biggest tip-off for me was the oil pressure gauge though, but I'm not certain. What are your thoughts?
  2. 67Dart273
    67Dart273 Well-Known Member
    38,979
    6662
    Oct 14, 2010
    Idaho
    Local Time:
    9:35 PM
    You have an oil pressure gauge? (Not a light?) then you have a Rallye dash cluster. In that case the IVR supplies all three gauges, oil, temp, and fuel.
    It is nearly impossible for the IVR to be bad and causing this problem IF the oil gauge works "normally."
    This is likely a bad sender, the engine "is" actually running warm, or else the sender wire is damaged and shorting some of the time.
    • Agree Agree x 1
    • Chained_360
      390
      107
      Nov 11, 2015
      Anchorage, Alaska
      Local Time:
      8:35 PM
      It is a Rallye gauge, but the factory oil gauge has never worked until it went haywire tonight. The previous owner installed an aftermarket mechanical gauge that reads normally. I will replace the temp sender though, they're pretty cheap
    • harrisonm
      harrisonm Well-Known Member
      1,927
      1226
      Jan 16, 2005
      Topeka, KS
      Local Time:
      4:35 AM
      What he said. The IVR feeds all three gauges, so approach your problem as though the gauges or the sending units are bad.
    • 67Dart273
      38,979
      6662
      Oct 14, 2010
      Idaho
      Local Time:
      9:35 PM
      Oh so you only have one working gauge. Well then could BE IVR. One thing you can do is scare up some resistors to use for testing. This imitates the old factory gauge tester, here:
      Someone edited this photo "handily" to display the resistors involved. All three gauge senders and all three gauges operate the same scale
      • Like Like x 1
      • Thanks! Thanks! x 1
      • cannucky
        cannucky The Guy With No Birthday
        5,725
        653
        Sep 25, 2008
        Portage Du Fort QC
        Local Time:
        9:35 PM
        without having any guages that work it's pretty hard to tell if its the IVR , is it even an IVR or us it still the VR in the fuel guage ?
        • Agree Agree x 1
        • 66jim
          66jim Well-Known Member
          169
          113
          Dec 11, 2007
          Local Time:
          12:35 AM
        • Frnknsteen
          Frnknsteen FABO Gold Member FABO Gold Member
          525
          301
          May 26, 2011
          Spencer, IN
          Local Time:
          12:35 AM
          I don't know about the A body gauges. My experience is from when I rebuilt my '69 B body rally gauges. I would think you could test the IVR to make sure it is putting out the 5 volts needed, or if it is running high. Found an interesting video of someone testing them (It was on a '67 Fury, but the method should be the same).
          As volts go up, so will your gauge readings.
          • 66jim
            169
            113
            Dec 11, 2007
            Local Time:
            12:35 AM
            to read IVR voltage just remove the water temp sensor and measure from the sensor wire to ground. The IVR for stock gauges should be 5V. If its a stock mechanical regulator its a duty cycle averaged 5V
          • 67Dart273
            38,979
            6662
            Oct 14, 2010
            Idaho
            Local Time:
            9:35 PM
            OP if you can take the cluster out there are some things you can do. I would ASSUME the IVR is bad and either build or buy a solid state replacement
          • Chained_360
            390
            107
            Nov 11, 2015
            Anchorage, Alaska
            Local Time:
            8:35 PM
            Awesome, thank you all for the responses! 67Dart273, thank you for the picture of the resistance test, I will try that after I test the temp sending unit. I'll start by testing all the sending units as soon as I get the chance and report back here.
            And I do plan on pulling the cluster soon-ish to install a tach and replace the bulbs, so when that happens I will go ahead and replace the IVR regardless if it's good or not. Thanks again! I'll keep everyone updated as I make progress
          • ChuckDock
            ChuckDock Well-Known Member
            102
            34
            Jan 7, 2018
            Goodrich, MI
            Local Time:
            12:35 AM
            I love this site. I had the same issue, gauges were pegging. I installed a new radio and had the dash out but not really sure what got disconnected. I read through this thread and the looked at my cluster and didn't see how it got ground at all so I made a ground strap, screwed it to the metal part of the cluster and put the other end to ground, problem solved!
            • Like Like x 1
            • oldkimmer
              oldkimmer FABO Gold Member FABO Gold Member
              10,064
              1111
              Nov 11, 2006
              Kindersley, Saskatchewan,
              Local Time:
              11:35 PM
              Have u checked to see if the oil pressure wire under the hood is maybe touching something metal and causing the gauge to fluctuate Kim
