Hello. I have a 1968 Dart and the brakes were changed to discs and larger rear drums from the original power drums. I need help identifying what I have. The previous owner thought the brakes were from a later Dart but I do not think so. Also, the master was not changed from the original. I have not driven the car yet so I can't tell you how they perform. The brakes have the following codes stamped into them: KH8 8186. The discs are about 10.75 in diameter, the disc pads use pins. Can someone tell me what they are from, please?
Also, the rear brakes were changed but I'll start with the fronts first. I will attempt to upload three photos which will help, I'm sure. By the way, that's chalk on the caliper!
Thanks in advance. Bill
