Need Help!!: Will A 1970 Truck Four Speed Fit Into an A Body?
Manual Transmission & Clutch Discussions
  1. 48james
    48james Well-Known Member
    87
    13
    Jun 23, 2012
    Hookstown,PA
    Local Time:
    2:59 AM
    Okay guys, so I found a craigslist add with a 318 and four speed cheap. Only thing is it's in a two-wheel drive truck frame. I would love to swap this into my 1972 Dart, are there any real differences?
  2. ssba
    ssba Well-Known Member
    2,294
    347
    Dec 29, 2009
    rensselaer in
    Local Time:
    2:59 AM
    Best answer, no. Forget about it.
    Of course anything can be done with a torch and welder
    but to many reasons to list why you shouldn't.
  3. 67Dart273
    67Dart273 Well-Known Member
    39,803
    7421
    Oct 14, 2010
    Idaho
    Local Time:
    12:59 AM
    Is it an actual "truck" 4 speed or an 833? They DID put those (OD at least) into half ton pickups and vans. Have you seen it? Photos?
    The bell will do you no good
  4. RustyRatRod
    RustyRatRod 30 Degrees Outta Whack FABO Gold Member
    53,008
    20851
    Jun 7, 2010
    Georgia
    Local Time:
    3:59 AM
    The truck transmission to my knowledge were all over drive unless they were the NP435 double low first gear transmission. If that is what it is, then the answer is no.
    However, if it is a real A833 truck transmission, I believe it would have to be the overdrive unit. They were not installed in trucks as early as 1970. BUT, it that is what it is, then yes, that will fit in an A body. It will require relocating the shifter, since it is not in the same location as the A body transmission, or you can swap the tail shaft out for an A body unit.
    First, determine which four speed it is.
  5. 67Dart273
    39,803
    7421
    Oct 14, 2010
    Idaho
    Local Time:
    12:59 AM
    As always.............
    [​IMG]
  6. RustyRatRod
    53,008
    20851
    Jun 7, 2010
    Georgia
    Local Time:
    3:59 AM
    Pretty much.
  7. 48james
    87
    13
    Jun 23, 2012
    Hookstown,PA
    Local Time:
    2:59 AM
    I don't have any pictures of just the tranny but its so close to me and cheap (since I am a broke ass 19 y/o:eek:ops:). I looked it up and seemed to find info saying there was one four speed from a light duty truck that would work, and also another that would need too much cutting to work. Any info on that? Think you can tell by the linkage?
  8. 48james
    87
    13
    Jun 23, 2012
    Hookstown,PA
    Local Time:
    2:59 AM
    I think the best bet will be to call and have them give me the bell housing numbers? Since I am 1100 miles away:violent1:
  9. jas0162
    jas0162 Well-Known Member
    343
    161
    Apr 23, 2014
    kansas
    Local Time:
    2:59 AM
    The NP435 granny four speed is a big iron chunk with an aluminum top cover with a shifter sticking out of it, it has no slip yoke and no external linkage. It wont fit without serious mods to the car and driveline. The 833 trans that will work in your car has outside linkage and the shifter bolted on the extension housing. It is pretty easy to tell them apart.
    • Like Like x 1
    • 48james
      87
      13
      Jun 23, 2012
      Hookstown,PA
      Local Time:
      2:59 AM
      Thanks JAS! That was the info i found but forgot where! I'll get some pictures, but where in kansas are you? I'm going to school in McPherson
    • j par
      j par Well-hung Member
      14,402
      6810
      Jul 2, 2014
      Portland Oregon
      Local Time:
      12:59 AM
      You could post a link to the Craigslist ad ?
    • 48james
      87
      13
      Jun 23, 2012
      Hookstown,PA
      Local Time:
      2:59 AM
      I would but it is for a truck frame with 318 and four speed, no close ups of the trans
    • jas0162
      343
      161
      Apr 23, 2014
      kansas
      Local Time:
      2:59 AM
      I live a few miles outside the sprawling metropolis of Mound City.
    • 67Dart273
      39,803
      7421
      Oct 14, 2010
      Idaho
      Local Time:
      12:59 AM
      Any "truck" (or van) which has SIDE linkage is going to "actually" be a passenger car transmission. In some years it might be a THREE speed. So you need to look for external shifter, and THREE separate shift levers
      If you Google A-833 you'll find lots of photos.
      What WE need is "what this is?" See if the guy will email a photo?
    • 48james
      87
      13
      Jun 23, 2012
      Hookstown,PA
      Local Time:
      2:59 AM
      Got ahold of the seller and he tells me its short and shifts from the top, with no external linkage so that means its a NP435 and won't work at all in an a body..?
    • dartnabout
      dartnabout FABO Gold Member FABO Gold Member
      10,396
      2917
      Aug 27, 2007
      Central PA
      Local Time:
      3:59 AM
      Right! What RRR said. They did not put the 4 speed OD in the early trucks. I am not sure what year they appeared but I think it is Early 80's and maybe the late 70's. I am aware of one that is/was in a you pull it yard and they get about $150. But if you don't have a manual car you get into clutch pedals and Z bars and everything else. PM me if you want I am in central PA.
    • RustyRatRod
      53,008
      20851
      Jun 7, 2010
      Georgia
      Local Time:
      3:59 AM
      So then you dont think anyone in the WORLD could possibly tell the difference? Then why on earth are you asking for OUR help if you think that?
    • RustyRatRod
      53,008
      20851
      Jun 7, 2010
      Georgia
      Local Time:
      3:59 AM
      Well, yeah I guess it could, but you'd have to cut out half the transmission tunnel to do it, fab new clutch linkage and the shifter would stick over the dash.
      It's a truck transmission. It is not designed to go in a car.
    • AJ/FormS
      AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s FABO Gold Member
      16,299
      5065
      Jan 19, 2014
      South-Central Manitoba,Canada, 900ftelevation
      Local Time:
      2:59 AM
      And the ratios in that farm truck 435tranny are for working on soft ground, pulling heavy loads, or school buses, and the synchros will not like 4000plusrpm
      The 833 O/D ratios are much better, but work best in low-rpm,hi-torque, applications;as in slantys and teeners..But these O/Ds didn't come out until loooong after 1970.
      I used to rebuild manual trannys including the 435. It nearly killed my back, and I was in my late 20's at the time.What Ima saying is they are tank 4-speeds. They have to be cuz the low gear is about 3ft tall. Ok so that's a stretch, but I'm remembering about 9 inches or maybe more, and it weighs about nearly as much as the entire 5pc geartrain of an 833. She's a tank all right.The case alone weighs nearly as much as my wife did when I first met her! A tank 4spd I tell ya....The synchros are inside out and nearly 6 inches in diameter, well, part of it could be 7 inches. Oh and BTW, that monster low gear IIRC,is un-synchronized.That's ok tho cuz you would never want to downshift into it anyway cuz the ratio was in the 8 to 10s I think. The shifter would probably smack the mirror on the way to third, but I doubt you could get third, cuz there would not be enough shift throw room available, to engage third. Or first for that matter. And to get out of forth you would need a back-seat passenger to shift it for you. You guys better get your timing right for a 4-3 shift! And it would be bucket seats only;and with that big stick between you and your girlfriend, there would be no room for nooky in the front seat.........................hah! I guess her parents would be ok with that tho........double hah! And you won't have to save quarters for the C-machine at the hotel, no mo....triple hah. She'll end up leaving you cuz the stick got in the way. That would be a switch.
      The bright side here is you get to stay a non-daddy for a bit longer.
      Ok my votes in.
      All kidding aside, be sure it's a passenger-car type tranny.
