I have a 69 Dart with a 360 engine that is built with a few HP parts but nothing wild. It has the original 273 radiator, 2949069. The radiator is clean and does a fair job of cooling as long as your not stopped. This is a original A/C car and i have installed all the A/C parts back on the car but I haven't charged it yet because the cooling system needs to be improved first. I have the MP clutch/fan package on it, P4120758. I do not have a shroud on it and i do not believe that in itself will make it run cool enough especially if I charge the A/C. Problem is the fan clutch set up is real close to the radiator, like one inch. So if I add a thicker radiator or recore mine to a 3 pass I will wind up with less clearance. So my question is how have some of you dealt with this issue and what is recommended for a radiator. The car will cruse all day long at 180 degrees as long as I'm moving. Thanks in advance for your help.
