Need help with component selection
Ccrussell
Pine bush ny
Hello,
I have been collecting parts for my turbo installation, but I am stalled at this point as I don't know what to purchase . I need a waste gate and blow off valve. When I look on eBay I am left unsure and just want to pull the trigger but don't want to waste money.
Have every thing else, turbo is a Holset , have the fuel system, plumbing , J pipe, carburetor, etc.
This will be a blowthru setup running a maximum 10 # boost, (at least until it is sorted)
Any thoughts would be appreciated.
Thanks
Look for a 50mm bov and a 44mm wastegate. Check to see what springs are in them as these can be adjusted easy. uy the one with the spring closest to your initial boost setting. As we all know you will want to turn it up more later. i would get the baseline spring and work from there.
VSRacing
This is some of the best budget friendly turbo parts on the market today.
If you go the ebay route make sure you disassemble everythink, check for burs and fitment, and make sure the diaphragm isnt torn.
