Need help with duster door glass.
BigStrok3
Mopar!
St.louis area
Wondering how exactly these come off the glass. Need to remove them from the old one to install on a new glass. Tried turning the washer on top with the 2 holes and nothing will budge. Thanks!
guy at the shop i hang out at has small bar with 2 pegs on it. pegs go on the holes and the turn counter to loosen and clockwise to tighten.
Bruce
I tried the needle nose pliers and couldn't get them to budge. I just went out tonight and got some PB blaster to try on them. If I have to I can make a tool with a couple studs in it to fit the holes.
you can use the keylock for a makita 4" grinder for switching the disks.
Bruce
Bruce
^^^^^^ This is right on. I found this out when I was changing a door glass. The one off my cheapo angle grinder looked different but worked great.
Get an adjustable and multi size spanner wrench
