Need help with wheel studs
Tires and Wheels (Mopar Hubcaps Too)
  1. RogerCox
    RogerCox Well-Known Member
    129
    22
    Sep 30, 2020
    Visalia Ca
    Local Time:
    8:20 AM
    I have a 67 barracuda (slant 6) 7 1/4 axle (5x4 bp)
    what part number Dorman wheel stud do I need for rear, and what part number for front?
    seeing so many options, thanks for the help!
  2. 4spdragtop
    4spdragtop CONGRATS NORTH AMERICA! FABO Gold Member
    32,470
    13580
    Aug 28, 2009
    Wasting time here
    Local Time:
    10:20 AM
    Drum size on rear? Also front disc or drum? Makes a difference
  3. dadsbee
    dadsbee FABO Gold Member FABO Gold Member
    1,249
    2756
    Nov 25, 2020
    Penetang, Ontario
    Local Time:
    11:20 AM
    @mobileparts
    Just do it once and do it right.. I'm sure he'll be right along !
  4. Alaskan_TA
    Alaskan_TA Well-Known Member
    6,153
    4704
    Nov 12, 2004
    PA
    Local Time:
    11:20 AM
    RH thread for passenger side & LH thread on the drivers side too.......
  5. RogerCox
    129
    22
    Sep 30, 2020
    Visalia Ca
    Local Time:
    8:20 AM
    8” drum (inside measurement) on rear, drums on the front as well.
    RH thread..??
  6. 4spdragtop
    32,470
    13580
    Aug 28, 2009
    Wasting time here
    Local Time:
    10:20 AM
    Mopars from factory had idiotic LH threads on drivers side front and rear. Those can be changed to RH thread if you want.
    Disc/drum are different studs.
    If noone gets you numbers here, go to Rock auto website and grab the part#'s
  7. LO23M8B
    LO23M8B Well-Known Member
    1,449
    730
    Jan 30, 2019
    Michigan
    Local Time:
    8:20 AM
    9 inch they never made 8 inch.
  8. pishta
    pishta I know I'm right....
    21,427
    10808
    Oct 13, 2004
    Tustin, CA
    Local Time:
    8:20 AM
    They should have never made the 9's they suck even in a 6.
    • Agree Agree x 1
    • RogerCox
      129
      22
      Sep 30, 2020
      Visalia Ca
      Local Time:
      8:20 AM
      Sorry 9” drum.
      only one wheel stripped every stud off, (driver rear) all the others came off easy.
      used Dorman 610-083.1 and worked great
      • Like Like x 1
      • CRUZE 418
        CRUZE 418 FABO Gold Member FABO Gold Member
        1,071
        469
        Mar 11, 2019
        Illinois
        Local Time:
        10:20 AM
        The drivers side is left hand thread, which way did you turn to twist them off?
      • RogerCox
        129
        22
        Sep 30, 2020
        Visalia Ca
        Local Time:
        8:20 AM
        twisted left ( counter clockwise)
      • CRUZE 418
        1,071
        469
        Mar 11, 2019
        Illinois
        Local Time:
        10:20 AM
        Sounds like someone had already changed the left front then. The studs were sorta copper colored, with an L stamped in the end of the stud. You can knock your old ones out for comparison for right hand studs. Think they changed over to right hand studs in '71.
        • Agree Agree x 1
        • djpearce
          djpearce Well-Known Member
          104
          14
          Oct 8, 2008
          Ocoee,FL
          Local Time:
          11:20 AM
          The "L" stamp on them is for left hand thread
          • Agree Agree x 1
          • Swinger 340
            Swinger 340 Well-Known Member
            74
            52
            Jun 9, 2021
            Lake Placid, Florida
            Local Time:
            11:20 AM
            Cruze, I had a 72' with left hand threads.
