Need lot of driveshaft & 8.75" rear end help
daniel_depetro
Warren, Michigan
OK driveshaft gurus I need some serious help...
We put a 360/727/8.75" in my fathers 1972 Dart Swinger. Car was originally 318/904/7.25". Obviously the driveshaft will no longer fit. (There is a 95% chance the car will be getting a manual gearbox)
1. What is the proper length driveshaft that we need?
2. I was wondering what transmission/drivetrain combos were the same length. (are 904/727/1967-74 B&E-body A-833 4-speeds the same length?)
2. Can we get a factory shaft out of any car to work if we use the shorter A-body 4-speed?
3. Is there any website or info anywhere that states the transmission/rear end/driveshaft length combinations?
Sit down and rea this part a few times. I apologize for being so scattered:
We currently have a 1941 Dodge 2-door sedan that they used the drivetrain from a Plymouth Road Runner (383/4-speed/8.75"/driveshaft). The 383 was replaced with a supercharged 360 but my father is toying with selling the 1941 Dodge and installing the supercharged engine in the 1972 dart and dragging that. If he sells the 1941 Dodge he wants to pull out the 4-speed & 8 3/4" sure-grip rear and stick in the stock 360 from the Dart, either a 3-speed manual transmission or a 904/727 and a smaller 7.25"'/8.25" rear end. He also has a 1972 Dodge Charger SE (318/904/8.25") that will eventually be 440 powered and the 4-speed & sure-grip 8.75" rear (from the 41 Dodge) would be great if the rear will fit right in. I thought these Late model B-body Chargers had a little wider rear than the rest. Is this correct? Will the Road Runner 8.75" rear bolt right in or were the spring perches different? A lsightly narrow rear would be great providing it isn't a bunch of work. If it is too much work than we might as well narrow one down. Other than a 1971-74 8.75" is there an 8.75" rear that will bolt right in?
that is the correct way to measure it. remember to back the trans yoke out of the tailshaft about an inch or so before you measure. this will give you the slack needed to get the shaft out of the pinion yoke.
i used a driveshaft out of a 70 coronet in my 64 dart, worked at stock length for a 904-to-7.25" combo but had to be cut down for the 8.75" rear, no biggie.
-tim
Thanks Tim.
I am just trying to avoid cutting down my 'extra' driveshafts. Just hoping I have some 'extras' that may work.
My dad has more cars than I do and less money so I'd be nice to not spending $100.00/driveshaft. he needs quite a few driveshafts for this coming spring/summer.
Interesting chart...
I've got a Scamp and I'm still wondering what length my driveshaft needs to be shortened to for the 8 1/4 that's going in soon. It has a 904 & 7 1/4 now soon to be a 904 & 8 1/4.
Why does it list two different length drive shafts for the same car (Duster, Dart Sport), rear end (8 1/4) and transmission (904):
3467151 1973-76 3.25 49.90 904/833 8-1/4 225 318 340 360 Duster Dart Sport
2996137 1973-76 3.25 51.89 904/833/230 8-1/4 225 318 340 360 Duster Dart Sport
Why is one listed as almost 2" longer then the other for the same vehicle??
When I had mine built for my 8 3/4 and 4-speed my shop told me to measure from the very back edge of tailshaft housing (behind the rear seal!), to the flat part on the yoke where the u-joint straps bolt on. Mine fits perfect and works great. Make sure to get it balanced when you are done!
the reason they list two different sizes is because yhey make two different yokes on them they make a long one & a short one
