lilredridinghoo
that´s just a question to get some input, what could/shoud be used on my 318, which should replace the 273 sitting in the fish
here are my basics
Engine
-318 from 1969 (pulled out of a 1969 charger) 0.030 over (engine was rebuild to standard specs. in the states about 1100 miles before, Flat topped pistons etc...)
Drive-Train
-Stock Converter
-904 Pushbutton Tranny
-8 3/4 Rear with 3,23:1 (Nitro-Gear-Suregrip)
parts i have laying around in the cellar or i will use from the current 273
- a mopar - windage tray to use (new)
- an edelbrock RPM-Performer Intake (dual) (new)
- FBO - Ignition (out of my fish - will swap it from the 273 to the 318)
- a 525cfm RoadDemon jr.
Exhaust - the plan is: to fabricate some hand-made headers (i knew my mate who has to weld them, would hate me :-D. 1 3/4 tubes 3" collector, and 2,5" dual pipes with low restriction mufflers)
as Mopar-Heads are not really available on the cheap side in Germany (and due to the budget), i´d decided to stay with a pair of 318 Heads (cast. 2843675) and spended some hours porting them as far as i dare to go with my grinder (gasket matching, opening the runner a little bit, a bit grinding in the bowl and smooting the valve guide)
now it comes to points to think about cam and lifters... what would you recommend - the car would be used on the street (most of the times) but should also be able to get some respectable times on the strip.
every input is appreciated - the goal is to show the chebby-guys here in Germany how old Mopars can perform....
here are my basics
Engine
Drive-Train
-Stock Converter
