Need some junk plastic for repairs
Cars and Mopar Parts Wanted
Thread Status:
  1. 4spdragtop
    4spdragtop CONGRATS NORTH AMERICA! FABO Gold Member
    32,446
    13557
    Aug 28, 2009
    Wasting time here
    Local Time:
    4:51 AM
    Contact Seller
    Hi, looking for some plastic pieces, maybe 2"x2". I need it to aid in re-attaching my dash lenses in my 69 cuda bezel. If im correct, you just can "shave" thin strips and mix it with a small amt of acetone correct??
    Thanks
    4spdragtop
  2. va58
    va58 Restoration Jedi
    624
    31
    Sep 7, 2011
    Smithfield,Va.
    Local Time:
    5:51 AM
    That is correct...
  3. CUDACOX
    CUDACOX Well-Known Member
    4,118
    104
    Jun 28, 2009
    Innisfil, Ontario, Canada
    Local Time:
    4:51 AM
    Steve, I have rebuilt a couple and just used some good clear silicone.Works great! I see trouble when melting plastic!
    • Like Like x 1
    • 4spdragtop
      32,446
      13557
      Aug 28, 2009
      Wasting time here
      Local Time:
      4:51 AM
      When you say silicone you talking like in the caulking gun?? 3 outta the 4 pegs I re-soldered down with the plastic. I would prefer to use plastic if someone has some spare junk pieces. Thanks bud, I hit yer spanks button!
    • Oklacarcollecto
      Oklacarcollecto Life is an experiment
      17,036
      297
      Mar 13, 2009
      North Central Oklahoma
      Local Time:
      4:51 AM
      A member on here used cassette cases for the plastic. I remember some pictures and it looked great but I don't recall which thread.
      • Like Like x 1
      • 4spdragtop
        32,446
        13557
        Aug 28, 2009
        Wasting time here
        Local Time:
        4:51 AM
        Thanks Bill, now to turn back the time-machine and figure out where I left my cassettes.....LOL
      • va58
        624
        31
        Sep 7, 2011
        Smithfield,Va.
        Local Time:
        5:51 AM
        Steve, you can also use the leftover plastic from any car,plane, or ship model. The leftover trees you remove the parts from if you have any of those laying around.
        • Like Like x 1
        • 4spdragtop
          32,446
          13557
          Aug 28, 2009
          Wasting time here
          Local Time:
          4:51 AM
          Thanks Tim!! I punched yer button too!!
        • moparclown
          moparclown Well-Known Member
          1,521
          11
          Aug 19, 2008
          Local Time:
          4:51 AM
          Steve
          I repair grilles and plastic parts all the time and tried the shaved plastic/acetone and it works but is also very brittle after the stuff fully dries.
          Go to the hardware store and buy a product made by Devcon called plasti welder,its a small two part syringe that you mix up the two parts and apply.
          Best stuff I have found so far and its about $6
          Just to give you an idea of how well it works
          in the first pic all those 72-74 cuda grilles were broken in half and missing pieces including the blue one which is the grille hanging on my wall at the bottom in primer in the 2nd pic
          Doug
          • Like Like x 1
          • Oklacarcollecto
            17,036
            297
            Mar 13, 2009
            Local Time:
            4:51 AM
            You don't have anything like Salvation Army, Goodwill or thrift stores up there? A CD/DVD case might be the same type plastic.
          • ir3333
            ir3333 Well-Known Member
            5,075
            1592
            Jun 1, 2008
            ontario,canada
            Local Time:
            4:51 AM
            acetone works best on abs plastic.
            go to your local body shop and grab some busted grill pieces
            just test until you get the correct abs
          • daredevil
            daredevil Well-Known Member
            10,983
            148
            May 19, 2007
            S/w Houston
            Local Time:
            4:51 AM
            You can probably find some peices at any buzy intersection. I know here in houston I observe signals fog lights and grill peices everyday.
          • seabee
            seabee FABO Gold Member FABO Gold Member
            2,488
            657
            Dec 20, 2009
            Bonita, CA
            Local Time:
            2:51 AM
            I use Plast-Aid a lot. Mix the plastic powder with the solvent, wait a few minutes until it is a putty, and shape it how you want.
            [ame="http://www.youtube.com/watch?v=NySFkteZ8M0"]Plastic Repair Kit - Plast Aid - YouTube[/ame]
            • Like Like x 1
            • Rocky_JS
              Rocky_JS 'cuda
              4,187
              160
              Feb 27, 2011
              Highland Maryland
              Local Time:
              2:51 AM
              use a small piece of the current dash above the noise suppressor, there is a no/low stress ledge, just shave some small pieces. I use a soldering iron with a needle point and a few shavings and melt them back in then flatten against the holes it's worked for me.
              • Like Like x 1
              • 4spdragtop
                32,446
                13557
                Aug 28, 2009
                Wasting time here
                Local Time:
                4:51 AM
                Thanks all, I forgot about Devcon Doug, I think someone else mentioned that in another thread I was checking.
                Im going to chk out for the Plast-Aid as well..interesting stuff.
                thanks again!!
              • RedFish
                RedFish Well-Known Member
                25,021
                3717
                Sep 5, 2007
                Local Time:
                5:51 AM
                Unless you like milky white plastic you wont use acetone on clear plastic.
                A run or drip can ruin your lens.
              • ram45red
                ram45red Well-Known Member
                566
                8
                Oct 18, 2011
                kershaw sc
                Local Time:
                5:51 AM
                If you need it I have a speedometer lense and a busted grill out of a 73 dart swinger.
              • 4spdragtop
                32,446
                13557
                Aug 28, 2009
                Wasting time here
                Local Time:
                4:51 AM
                Thanks Ram, my lenses are good, Im gonna try using the "model trees" that VA58 said to try. Thanks!!:cheers:
              Thread Status:
