Need some turn signal school
Electrical and Ignition
  1. j par
    j par Well-hung Member
    24,426
    12763
    Jul 2, 2014
    Portland Oregon
    Local Time:
    10:45 AM
    it seems like I don't have no power up there anywhere except for like I was saying that horn. Also I haven't got into the actual wires I'm just tested up at the top. But that's interesting that I have brakes and now no signal so here we go...
  2. j par
    24,426
    12763
    Jul 2, 2014
    Portland Oregon
    Local Time:
    10:45 AM
    Having brake lights gives me hope I can resolve all this.
  3. Cuda Al
    Cuda Al Well-Known Member
    1,086
    1198
    Oct 21, 2007
    Lompoc, CA
    Local Time:
    10:45 AM
    Remove the turn signal blinker and put a jumper in there, key must be on to test.
    You should now have a constant power at the column, if not then the problem is down stream.
    Alan
    • Like Like x 1
    • j par
      24,426
      12763
      Jul 2, 2014
      Portland Oregon
      Local Time:
      10:45 AM
      okay I'm in there now and I'm finding some power at the pink wire with the blinker switch on. Right now I just checked the trunk area and it looks good. I put a light bul in the trunk light and it came on. it flickered when I played with the wires which wasn't good but also once it was on the button for the trunk to shut it off was not working I couldn't get it to shut off without pulling the balb. I'm sure that's its own separate problem. But what I'm getting at back there was making sure the wires look good and they do. Also I had in my mind some connections going back to the back could be given problem but probably not because again the brake lights and regular lights both work so the two ways are definitely connected. I still feel my problem is under the dash. I was thinking now to take my voltmeter and put one lead on the power and poke around?
    • j par
      24,426
      12763
      Jul 2, 2014
      Portland Oregon
      Local Time:
      10:45 AM
      One more little tidbit I never get anything to ever light up in the dashboard for any reason whatsoever.
    • j par
      24,426
      12763
      Jul 2, 2014
      Portland Oregon
      Local Time:
      10:45 AM
      So I know the Flasher is getting power because when I have the ignition on the Flasher will cut the power. So if I unplug the Flasher there's no power to the red wire in the blinker control?
    • Jadaharabi
      Jadaharabi FABO Gold Member FABO Gold Member
      7,505
      8140
      Jan 8, 2016
      Peoria, Illinois
      Local Time:
      12:45 PM
      Long ago, I replaced the turn signal switch in my 68 Dodge truck.
      Put everything back together and only had brake lights. Long story short the contact rod that jumps across the contacts had to be slightly bent to make contact when switching to turn.
      • Like Like x 1
      • j par
        24,426
        12763
        Jul 2, 2014
        Portland Oregon
        Local Time:
        10:45 AM
        Okay a little more information here. At the Flasher itself I have a strong electrical at all times going to the Flasher seemingly no matter what position the key is in. And when I check with my check light there's a strong signal at the incoming wire and a weak signal at the outgoing wire? I can't believe this is going to end up being a flasher cuz I swear that's a thing that I change first. And it says Made in America on the outside of it.
      • j par
        24,426
        12763
        Jul 2, 2014
        Portland Oregon
        Local Time:
        10:45 AM
        Well maybe I'll try another flasher damn it it's only 10 bucks. This time I had an old flasher I tried and it went from power to no power on the old flasher and power 2-week power on the newer flasher that I thought I replaced.a
      • j par
        24,426
        12763
        Jul 2, 2014
        Portland Oregon
        Local Time:
        10:45 AM
        As I go to think about all my electrical catastrophes from the beginning remember the amp meter is bypassed as in I just took those two big wires and connect them together. I'm wondering if that made it so the dash doesn't get any power at all?
      • Tooljunkie
        Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
        15,404
        14818
        Jul 22, 2017
        Manitoba
        Local Time:
        12:45 PM
        Brake lights go through the turn signal switch. Keep this in mind.
        There are 2 flashers, other one is hazards(constant power)
        Also feed through signal switch.
        • Like Like x 1
        • j par
          24,426
          12763
          Jul 2, 2014
          Portland Oregon
          Local Time:
          10:45 AM
          Doesn't the hazard flasher have like three wires on it or something? I just went down and got another flasher and it did the same thing as the replacement one. Good strong power at one side and then when plugged in had kind of weak power coming out of the other? I'll go take some pictures.
        • Tooljunkie
          15,404
          14818
          Jul 22, 2017
          Manitoba
          Local Time:
          12:45 PM
          Three wire-one is indicator/needs proper load to work.
          I do a lot of electrical stuff, its hard for me to wrap my head around it too.
          First go round with signals was wiring a universal switch into a M-37 for a buddy.
          The front and rear signals are isolated from each other for brake light function. Just to make it even more confusing. A good test light is the best. Turn off the meter and put it back in the toolbox.
          • Like Like x 1
          • j par
            24,426
            12763
            Jul 2, 2014
            Portland Oregon
            Local Time:
            10:45 AM
            Alright let's start working on that one!
          • j par
            24,426
            12763
            Jul 2, 2014
            Portland Oregon
            Local Time:
            10:45 AM
            I believe it's the horn relay LOL when I use my test light it made the horn honk when I touched one of the wires. And then it let the light up on that one and lit the light upon another one and no light on another one. All these things with switch off.
          • j par
            24,426
            12763
            Jul 2, 2014
            Portland Oregon
            Local Time:
            10:45 AM
          • j par
            24,426
            12763
            Jul 2, 2014
            Portland Oregon
            Local Time:
            10:45 AM
            BREAKING NEWS! I HAVE EMERGENCY FLASHERS ALL THE WAY AROUND FOR THE FIRST TIME SINCE I'VE OWNED THE CAR 5 YEARS! I FEEL VICTORY AROUND THE CORNER!!!LOL
            • Like Like x 2
            • blewbyoutobad
              blewbyoutobad Well-Known Member
              932
              239
              May 23, 2010
              Missouri City, TX
              Local Time:
              12:45 PM
              Run a hot 12V jumper to the red wire on the column for the signal switch and see if that works. If so then at least you know your wiring for the switch and lights is good. Its just a matter of where the break is then.
              • Thanks! Thanks! x 1
              • j par
                24,426
                12763
                Jul 2, 2014
                Portland Oregon
                Local Time:
                10:45 AM
                I found out in my parts bin what looks like maybe the original blinker clicker mechanism. I brought it in and tried it and the flashers worked opposite? Well I could see the backwards wiring between the two different Clickers. But still no turn signal when the turn signal clicker is clicked? Now I'm not suspecting it being the clicker itself.
              • j par
                24,426
                12763
                Jul 2, 2014
                Portland Oregon
                Local Time:
                10:45 AM
                With the four way flashers working and the brake lights working this should be pretty well isolated now.
              • j par
                24,426
                12763
                Jul 2, 2014
                Portland Oregon
                Local Time:
                10:45 AM
                And here's another question is the Flasher the Flasher for all flashing? Like for each side and for both sides?
              • Jadaharabi
                7,505
                8140
                Jan 8, 2016
                Peoria, Illinois
                Local Time:
                12:45 PM
                One flasher is for the four way.
                The other flasher is for the turn signals.
                • Like Like x 1
                • j par
                  24,426
                  12763
                  Jul 2, 2014
                  Portland Oregon
                  Local Time:
                  10:45 AM
                  Maybe I'm looking at the wrong thing and I need to find the correct flasher?
                  • Like Like x 1
                  • Tooljunkie
                    15,404
                    14818
                    Jul 22, 2017
                    Manitoba
                    Local Time:
                    12:45 PM
                    Isnt one up by the ash tray housing?
                    • Like Like x 1
                    • j par
                      24,426
                      12763
                      Jul 2, 2014
                      Portland Oregon
                      Local Time:
                      10:45 AM
                      And bingo! That was it. Change that new flasher over to ( ashtray/glove box area) one.
                      So tomorrow get one more flasher and put it all back together.
