Need urgent help on my Slant Six (throttle cable setup)
1966DartConvertible
Malaysia
Hi all
Im having trouble finding the correct setup for my RHD Dodge Dart Slant Six.
Can someone please take a closeup picture and measure the Rod pictured in this diagram below, item number 14-11-9, so I can fabricate something that will work on my car.
If your LHD Slant six is equipped with A/C, yours should be using throttle cable and very similar to the setup ive shown above.
Thanks again.
Syed
Malaysia
That looks like a kickdown linkage. Lokar and Buchillon Performance make a cable-type linkage in the event someone isn't able to give you the length of the rod. My '73 Dart has a cable operated throttle, but no rod like the one your diagram shows. I'll double check when the sun comes up as I have been wrong before.
Ok thanks. will be waiting :)
On my '73 the rod is flat and not round. It measured 6 1/2" with a 2" slot in one end. (1 barrel
My '72 with a 2 barrel measure 7 1/4" with a curved 2" slot in one end.
The rest of the brackets look the same as the diagram except my rod is a flat bar.
I see in your diagram there are two rods labeled 14-11-9....I measured the upper ones...near the carb. The shorter one.
Will try and see what I can do :)
Although I dont know how different the measurements would be as yours is a '73 with a Holley 1945 (I think) and mine should be Holley 1920.
Thanks.
Syed
Did you notice on your diagram the two rods labeled 14-11-9?
Which rod do you need the measurement of? Upper short one or lower long one?
