[WANTED] Needing stock 8 3/4 10x1.75 sbp drums
Cars and Mopar Parts Wanted
Thread Status:
  1. canuckgts
    canuckgts Member
    11
    0
    Oct 15, 2011
    ontario
    Local Time:
    10:44 AM
    Contact Seller
    Hi all. I have my 8 3/4 ready to bolt in. New everything including brake shoes and hardware.
    Just found out, no drums available for my setup.
    Shoes are the 10x1.75. Axles are sbp.
    Anyone have a good set of original drums to fit my application?
    Thank you in advance.
  2. SGBARRACUDA
    SGBARRACUDA ROY FABO Gold Member
    17,422
    6131
    Dec 7, 2006
    PLANT CITY FL. and PERRY GA.
    Local Time:
    11:44 AM
    Centric makes new ones that are inexpensive. Check with Rock Auto.
  3. canuckgts
    canuckgts Member
    11
    0
    Oct 15, 2011
    ontario
    Local Time:
    10:44 AM
    Thanks for the reply. The centric drums info link gives no dimensions. Someone else on this sight has told me they are bbp, which I could buy and have drilled but,
    I am not sure about the quality of the material. Would like to find original if at all possible.
  4. 694spd
    694spd Well-Known Member
    996
    322
    May 2, 2014
    Upstate NY
    Local Time:
    11:44 AM
    I don't think that Rockauto has any rear 10" x 1.75" SBP rear drums listed.
    The listed CENTRIC 12363004 I believe is a 9" drum...
    Correct me, if I'm wrong.
  5. grampscamp
    grampscamp Active Member
    29
    9
    May 1, 2020
    Aldergrove B.C.
    Local Time:
    8:44 AM
    I have a set. I can get pics this weekend.
  6. canuckgts
    canuckgts Member
    11
    0
    Oct 15, 2011
    ontario
    Local Time:
    10:44 AM
    694spd Yes I believe you are correct. 12363004 is 9". They list 12363044 as 10" but not sure on bolt pattern.
    Going to wait and see what grampscamp has. In Canada even.
  7. canuckgts
    canuckgts Member
    11
    0
    Oct 15, 2011
    ontario
    Local Time:
    10:44 AM
    Gramscamp: That is awesome. Send pics when you can. Thank you
  8. MoparMike1974
    MoparMike1974 FABO Gold Member FABO Gold Member
    2,625
    1854
    Jun 16, 2017
    Maryland
    Local Time:
    11:44 AM
    I just got some from rock auto, they looked right to me. Guess I better double check them. Not the bell shape like original.
    Here is the ones I bought. Comes up as rear 10" brakes. Searched 71 dart 340.
    CENTRIC 12363044 Drum | RockAuto
    I will go and check against some originals and report back.
  9. Rocket
    Rocket FABO Gold Member FABO Gold Member
    1,980
    268
    Apr 22, 2005
    Manchester, CT
    Local Time:
    4:44 PM
    I bought a Centric set years ago in 10". They were SBP. Only thing I modified was where the hole for the axle register is on the outside of the drum, it has a slight rise in the casting. I ground it flat so there was no issue mounting the wheels. Not sure if this has since been corrected in the design.
    Some big auto parts stores may be able to get them to you as well like AugoZone, ...
  10. MoparMike1974
    2,625
    1854
    Jun 16, 2017
    Maryland
    Local Time:
    11:44 AM
  11. Avispa
    Avispa FABO Gold Member FABO Gold Member
    1,405
    852
    Feb 26, 2007
    Georgia
    Local Time:
    11:44 AM
    Pretty sure O'rielly's has them also, bout 50 bucks each.
  12. MoparMike1974
    2,625
    1854
    Jun 16, 2017
    Maryland
    Local Time:
    11:44 AM
    Nothing to correct, they are supposed to have that raised lip on the register. The original drum has it too.
  13. Rocket
    1,980
    268
    Apr 22, 2005
    Manchester, CT
    Local Time:
    4:44 PM
    Thanks for the clarification. Guess I never noticed.
  14. MoparMike1974
    2,625
    1854
    Jun 16, 2017
    Maryland
    Local Time:
    11:44 AM
    I verified it on some originals before posting to be sure. As far as I can remember, most drums have that raised lip.
  15. SGBARRACUDA
    17,422
    6131
    Dec 7, 2006
    Local Time:
    11:44 AM
    I just bought a set off Rock Auto less than a month ago. They are not the bell or darth Vader style. If I were home I could look on the invoice for the part number.
  16. canuckgts
    canuckgts Member
    11
    0
    Oct 15, 2011
    ontario
    Local Time:
    10:44 AM
    Thanks all. Going to see what grampscamp has, if that doesn't work out I will order from rock-auto.
    I checked the 12363044 at the Summit sight and they are sbp.
    Thanks again
  17. MoparMike1974
    2,625
    1854
    Jun 16, 2017
    Maryland
    Local Time:
    11:44 AM
    Yes, the 12363044 are the correct drums. Only difference is they are not the bell style, which is no longer available.
  18. canuckgts
    canuckgts Member
    11
    0
    Oct 15, 2011
    ontario
    Local Time:
    10:44 AM
    Hey Grampscamp any luck with the drums?
  19. 65Val
    65Val Average Length Member
    5,151
    1088
    Oct 14, 2005
    Victoria, BC, Canada, EH!
    Local Time:
    8:44 AM
  20. 68383GTS
    68383GTS Well-Known Member
    7,398
    883
    Nov 15, 2007
    East Peoria,IL
    Local Time:
    10:44 AM
    I have a set off a 68 383 GTS. They are small bolt but have also been drilled for big bolt.
  21. Daves69
    Daves69 Well-Known Member
    5,095
    3244
    Feb 20, 2011
    WestOfChi
    Local Time:
    10:44 AM
    What the Centric look like.......
    FWIW, My old drums were not "bell" style. Maybe replaced in the mid 70's, don't know for sure. Comparison pictures before re-drilling Centric......
  22. Slantsix64
    Slantsix64 Well-Known Member
    2,734
    1078
    May 11, 2014
    SGV
    Local Time:
    10:44 AM
    got two sets off rockauto workgreat
Thread Status:
