New BluePrint Engines 408 Shortblock Part #: BPC4085. Roller Cam Ready
BluePrint Engines
  1. Johnny Mac
    Johnny Mac www.blueprintengines.com FABO Vendor
    3,622
    2693
    Jul 10, 2010
    OHIO
    Local Time:
    8:25 PM
    Per your requests, I have come up with a new shortblock design based on our new, roller 408.
    Part #: BPC4085
    $2799
    Not on the website yet. may be a while for that. But I CAN/WILL take orders.
    • Roller Cam ready
      Cast Steel Crank
      Forged Pistons
    BLOCK:
    • Hand picked seasoned block
      Square and parallel decked
      Align honed main bearing bore
      Cylinders honed on computer controlled machine to within .0002 straightness and roundness
      Cylinders are sonic tested for thickness
      2-Bolt Main
      4.000" Bored .040" over
      2-Piece Rear Main Seal
      Mech fuel pump provision: Yes
    ROTATING ASSEMBLY:
    • New Cast steel crankshaft
      4.000" Stroke
      OEM type 6.123" connecting rods w/ 150,000 psi bolts
      Forged pistons
      Magnum Balance Snout, LA360 balanced rear
    • Supports cylinder heads/rockers that can utilize pushrod oiling only.
    • Like Like x 7
    • Thanks! Thanks! x 2
    • Phreakish
      Phreakish Well-Known Member
      826
      465
      May 28, 2015
      N. Idaho
      Local Time:
      5:25 PM
      Will it include the spider and lifter retainers? They can be tough to find if one is intending to do a roller build.
      They're either junkyard fodder or have to be gotten used (ebay, etc).
      If Blueprint has a source for those parts, it would be a great option for roller minded folks. So would whatever hydraulic roller lifters Blueprint is using since obviously you're able to make power with them!
    • Johnny Mac
      3,622
      2693
      Jul 10, 2010
      OHIO
      Local Time:
      8:25 PM
      • Like Like x 2
      • Johnny Mac
        3,622
        2693
        Jul 10, 2010
        OHIO
        Local Time:
        8:25 PM
        It will not include tray/dogbones. i'll have to dig and see where we are getting them.
        Lifters are fairly easy to source.
        • Like Like x 1
        • Johnny Mac
          3,622
          2693
          Jul 10, 2010
          OHIO
          Local Time:
          8:25 PM
        • Johnny Mac
          3,622
          2693
          Jul 10, 2010
          OHIO
          Local Time:
          8:25 PM
          @Mopar Tim says he will take two if noone else buys one this week. what a nice guy!
          In all seriousness, had a ton of guys in various threads recently asking for these. So i thank you all in advance for any action you can toss our way on these.
        • rumblefish360
          rumblefish360 So close, yet so far away FABO Gold Member
          38,356
          9992
          Jun 21, 2005
          New York, on a Island
          Local Time:
          8:25 PM
          Hey Johnny, I hate to sound stupid here but here it goes.
          Could you explain what’s in the quote.
          Will this take a neutral balance converter?
          Or do I need a B&M flexplate? Which one if so?
        • 4spdragtop
          4spdragtop FABO Gold Member FABO Gold Member
          29,097
          9283
          Aug 28, 2009
          Wasting time here
          Local Time:
          7:25 PM
          Tray/dog bones? Are those the holders for roller lifters?
        • rumblefish360
          38,356
          9992
          Jun 21, 2005
          Local Time:
          8:25 PM
          Tray is probably local lingo for the spider.
          Dog bones are what tie the lifters together and stop them from spinning around in there bores on the cam.
          • Like Like x 1
          • Thanks! Thanks! x 1
          • Johnny Mac
            3,622
            2693
            Jul 10, 2010
            OHIO
            Local Time:
            8:25 PM
            Hey Rumble. Not sure what ya mean? Short Block assembly is assembled crank, rods, pistons, and not much else. Ready for a customer to take it from there.
            Basically a bpc4085ct in short block form.
            BluePrint Engines 408CI Stroker Crate Engine | Small Block Chrysler Style | Longblock | Aluminum Heads | Roller Cam
            Yes, my answer is that typically aftermarket converters are mostly neutral Balance. Customer then get the correct flexplate. in this case, an LA 360 weighted one.
            Chrysler sometimes from the factory would weight converters, and use neutral flexplates. just keep yourself (and your converter builder) straight.
            Technically a factory LA360 flexplate will work, but for $100, idk if i wouldn't get a new one.
            it'll differ from 904 to 727, and check with converter company for bolt thread size.
            727
            B&M 10236 B&M Steel SFI Certified Flexplate - Mopar Small Block A727
            904
            B&M 10239 B&M Steel SFI Certified Flexplate - Mopar A904
            • Johnny Mac
              3,622
              2693
              Jul 10, 2010
              OHIO
              Local Time:
              8:25 PM
              if you don't want to buy "retrofit" lifters with the cross bar built in. Yes. "tray and retainer" is the OEM setup.
              probably $250-350 difference...but you also don't need to locate a tray/retainers.
              • Agree Agree x 1
              • Johnny Mac
                3,622
                2693
                Jul 10, 2010
                OHIO
                Local Time:
                8:25 PM
                @12many time to do a B-van? to tow the A-Van with?
                • Like Like x 1
                • 12many
                  12many Well-Known Member
                  1,219
                  1484
                  Dec 14, 2016
                  Changes
                  Local Time:
                  7:25 PM
                  Ive always wanted a b-series short panel, just very hard to find not all beat up! But I've got my tow vehicle for now to pull the "Little Van With The Stroker That Could"!!:lol:
                  • Like Like x 8
                  • Johnny Mac
                    3,622
                    2693
                    Jul 10, 2010
                    OHIO
                    Local Time:
                    8:25 PM
                    that truck is clean!!!!
                    • Agree Agree x 2
                    • Johnny Mac
                      3,622
                      2693
                      Jul 10, 2010
                      OHIO
                      Local Time:
                      8:25 PM
                    • Mopar Tim
                      Mopar Tim FABO Gold Member FABO Gold Member
                      19,856
                      12578
                      Nov 29, 2014
                      vista CA.
                      Local Time:
                      5:25 PM
                      PM sent, will more then likely take one....
                    • Johnny Mac
                      3,622
                      2693
                      Jul 10, 2010
                      OHIO
                      Local Time:
                      8:25 PM
                      Order entered! Mopar Tim gets #1! Officially on order! thanks !!!
                      • Like Like x 2
                      • superchargeddrt
                        superchargeddrt Well-Known Member
                        2,304
                        868
                        Aug 24, 2009
                        Pittsburgh, Pa.
                        Local Time:
                        8:25 PM
                        Hi Johnny,
                        I have a buddy that might be interested in ordering one of these after the new year. What's the lead time on getting one?
                      • Johnny Mac
                        3,622
                        2693
                        Jul 10, 2010
                        OHIO
                        Local Time:
                        8:25 PM
                        About 30 or 40 days right now. Thanks for the interest!!
                      • superchargeddrt
                        2,304
                        868
                        Aug 24, 2009
                        Pittsburgh, Pa.
                        Local Time:
                        8:25 PM
                        Thanks Johnny,
                        I'll pass that on to him.
                        • Johnny Mac
                          3,622
                          2693
                          Jul 10, 2010
                          OHIO
                          Local Time:
                          8:25 PM
                        • 74Dart318
                          74Dart318 Well-Known Member
                          438
                          94
                          Mar 20, 2009
                          az
                          Local Time:
                          6:25 PM
                          Thanks for the heads up Johnny!
                          • Like Like x 1
                          • Mopar Tim
                            19,856
                            12578
                            Nov 29, 2014
                            vista CA.
                            Local Time:
                            5:25 PM
                            @Johnny Mac , what is the shipping weight on this? I have to unload it from truck onto something...
                          • Johnny Mac
                            3,622
                            2693
                            Jul 10, 2010
                            OHIO
                            Local Time:
                            8:25 PM
                            Come with a liftgate service.
                            Probably 300 lbs
                          • TurboGLH
                            TurboGLH Well-Known Member
                            353
                            401
                            Jul 29, 2017
                            CT
                            Local Time:
                            8:25 PM
                            Couple of questions.
                            What's the piston dish size and how far is it in the hole?
                            Any chance on the name of the crank vendor?
                            I know you're using magnum blocks, do you have any early blocks in your collection, and would you be willing to put la cam bearings in one of you did?
