New carburetor rebuild?
Fuel and Air Systems
  1. Doug.S
    Doug.S 1964 Dart More Door
    107
    56
    Jan 21, 2018
    Saylorsburg, PA
    Local Time:
    12:38 AM
    So I just bought my first ever NOS carburetor. It is over 50 years old and still in its original box with tags and directions etc. can’t wait to get it on the car.
    Anyway, I want opinions. Should I disassemble this unit and replace all the gaskets and the needle and seat? Or should I just throw it on and start tuning it?
    Thanks for the help. Doug
  2. pishta
    pishta I know I'm right....
    13,888
    3592
    Oct 13, 2004
    Tustin, CA
    Local Time:
    9:38 PM
    What is it? Carter, run it. Holley? The gaskets may or may not be puckered under the metering block. NOS should be ready to run with maybe a blow out, spray down and a lube. Cant hurt to run it if your willing to tear it down if it doesn't run anyway.
  3. jas0162
    jas0162 Well-Known Member
    293
    132
    Apr 23, 2014
    kansas
    Local Time:
    11:38 PM
    put it on, watch for leaks. Iv used some old NOS carbs before and they worked fine (BBD and BBS).
    • Like Like x 1
    • teringer
      teringer ase master hall of fame
      721
      118
      Feb 22, 2011
      kenly nc
      Local Time:
      11:38 PM
      does it have a leather accelerator pump seal might need to soak it
    • Doug.S
      107
      56
      Jan 21, 2018
      Saylorsburg, PA
      Local Time:
      12:38 AM
      Thanks for the replies.
      Yeah it’s a carter BBS. I will throw it on and see what happens. I will try to squirt some gas into the accelerator pump and let that leather soften up before I give it a go. Thanks for that heads up.
    • txas2step
      txas2step FABO Gold Member FABO Gold Member
      109
      88
      Feb 16, 2012
      houston
      Local Time:
      11:38 PM
      Yes put some gas in the bowl and let it soak for a while. That Carter 1 barrel is pretty bullet proof. Nice find.
