New coil question
A56
MoPar Affliction
White Oak, N.C.
I'm looking to purchase a new stock replacement coil for my 340 cuda and I'm seeing that the coils for sale state that they now have silicone in them rather than mineral oil. Any insight on the reason?
:popcorn:
Do they look like a canister style replacement?? Or are they the iron-stack type (like a transformer)??
:popcorn:
Stock replacement
I have no experience with them. Modern "E" core coils are typically (I think) all epoxy. Oil was used for HV insulation and heat conductivity. I have no idea what the heat conductivity or insulation of silicone is Might be better, might not
The disadvantage to oil is that "some" coils if mounted in certain ways, "alleged" can expose the windings above the oil level, but in the day Mopars were mounted both vertically and horizontally, as were Fords. So who knows?
Of course oil can leak........
On a side note about "what is better" "It used to be" in high voltage and high power RF circuits, such things "in the day" as ceramic and mica were considered "the top of the heap."
BUT it turns out that during WWII some ceramic insulators were manufactured with less--than--ideal base material and did NOT have the insulating/ dielectric properties actually desired!!!
The disadvantage to oil is that "some" coils if mounted in certain ways, "alleged" can expose the windings above the oil level, but in the day Mopars were mounted both vertically and horizontally, as were Fords. So who knows? (I'm still going to mount it the way it came regardless)
My research shows that coils mounted horizontally if they "should" leak would then expose the windings due to depleted content. I thought maybe silicone was the cheap way out and that's why no mineral oil.
I don't know it this is a reason but Silicone is a K class transformer fluid, meaning it has a fire point above 300C.
Pertonix III and Flamethrower III coil!
Shrink wrap the extra dizzy wire and Hide the ballast bypass from behind and Smile! JMO!
I have the Petronics Flame Thrower, an epoxy coil. Just make sure that you get the correct ohm coil that you need.
It is more than That!
My coil looks totally stock.
If you follow the recipe from Pertronix it takes all the correct pieces including the Plug wires for total success!
I ran solid core "Taylor" wires with my orange/chrome and Gold Chrysler boxes. Great results however!
The Flame Thrower III with resistor core "Taylors" and the rest are superior! Never mind the fact it is all hidden like stock! Again JMO and 30 years!
Last word, Maybe!
Few read the lines and follow through as directed!
It seems inherent we all want to cheat the system and stop short, and or modify what the Manufacturer tells us!
In this case do not!
I have personally had several oil filled coils leak. I came to like the e core type, but have also found those aren't compatible with certain efi setups. Also have to watch resistance if mixing with old school ignition systems.
If it's a bone stock build, I would get whatever rock auto special was on sale, and buy a spare with it.
Also, am I wrong, all electronic ign should be spiral core not solid core wires. Stock electronic Mopar system is a .6 ohm coil? My Mopar electronic dist, I have the FAB ign module, 1.5 ohm Flame Thrower epoxy coil (per instructions) and the Flame Thrower ceramic end spiral core wires.
Hope we haven't confused the OP. I believe that any .6 ohm epoxy coil would suit his issue.
lol, not confused, interesting info thanks
Not according to DC in the 70's! Gold and Chrome were Solid core.
I had a coil fail & had to buy one right then. All they had at Oreilly was a masterpro, the house brand. It only lasted a couple months. Took it back and got Standard, thinking it was a good brand. Opened the box & it was the same exact coil. Can’t trust name brands anymore. All Chinese junk. Bought a more expensive chrome coil & it has lasted.
Unfortunately Standard, AND NAPA Echlin has been **** for a number of years. I've no idea if there is a "good" brand anymore, other than MAYBE finding a late model coil AKA Dodge RAM using a single coil, and buy one from the dealer or good used.
Pretty sure trans oil is cancer causing, hence now being alternatives being used. TO also has very poor heat con
The coil needs to be matched to the ign system. Points, electronic?
Yes, my distributor is the stock dual point that it came with in '69.
I have been searching for the proper coil for a dual point Prestolite dist, haven't really found an answer. Seems like points want a 3 ohm coil. So I was wrong thinking .6 ohm.
Having said all this, we do have a guy here, Halifax? Bet he knows. Why not pm him?
