440 source kit?Got the new 470 low deck installed. Can't believe the difference in room from the RB to the B. I can now replace the start without pulling the engine.
That is one clean installation, NICEGot the new 470 low deck installed. Can't believe the difference in room from the RB to the B. I can now replace the start without pulling the engine.
Whose tappet covers ?Got the new 470 low deck installed. Can't believe the difference in room from the RB to the B. I can now replace the start without pulling the engine.
Top Street Performance in Santa Fe, CA.Whose tappet covers ?
Any leakage problems ?
Without a dyno, I'd just be lying to you. The only 0.030" over 440 I had, had 915 heads. That was years ago. By the seat of the pants, this 470 seems a lot stronger.How much more power does it put out than an equally built 440 bored .030 over?
