New here and have a question
FABO Welcome Wagon
  1. Greg A Sutphin
    Greg A Sutphin 77AMC HornetX
    48
    30
    Feb 10, 2019
    North Carolina
    Local Time:
    3:47 PM
    I had a machine shop bore my 400, install the pistons on the rods and deck the block. I bought KB Hypereutectic pistons, 9.3:1 compression ratio, and when I get them back, the valve reliefs were on the bottom, closer to the exhaust port, of the pistons. As long as the valve clearance is good, should it be a problem? They rebuild a lot of engines and I am wondering if they screwed up big time. It's been a while since I had it done and now trying to sell the engine. Any info would be helpful. I am adding pics to conversation to show the delima I am having. Isn't the even cylinders on the passenger side of the block and the odd on the drivers side?
  2. SGBARRACUDA
    SGBARRACUDA ROY FABO Gold Member
    15,539
    4789
    Dec 7, 2006
    PLANT CITY FL. and PERRY GA.
    Local Time:
    3:47 PM
    Piston are installed wrong. Exhaust fly cuts and intake fly cuts are in the wrong place.
    • Agree Agree x 1
    • Greg A Sutphin
      48
      30
      Feb 10, 2019
      North Carolina
      Local Time:
      3:47 PM
      That's what I thought. Is it possible to flip them over and make them right or am I just screwed? I know some pistons have a certain direction to be installed. I see the arrow he drew on them.
    • Rmoore
      Rmoore Well-Known Member
      260
      119
      Nov 14, 2018
      Gun Barrel City, Texas
      Local Time:
      2:47 PM
      You can put the pistons in right. Need to make sure the rods are on correctly also. No big deal. No harm . no foul. Just need to look at everything .
      • Agree Agree x 1
      • SGBARRACUDA
        15,539
        4789
        Dec 7, 2006
        Local Time:
        3:47 PM
        No because the rods will be wrong. Valve arrangement should be E I I E E I I E. Hell you paid the machinist, Make do it right.
        • Agree Agree x 3
        • Greg A Sutphin
          48
          30
          Feb 10, 2019
          North Carolina
          Local Time:
          3:47 PM
          It's been too long. I know they won't correct them. I am meaning can they be flipped on the rods they are on? That's what I am hoping.
        • j par
          j par Well-hung Member
          19,884
          9788
          Jul 2, 2014
          Portland Oregon
          Local Time:
          12:47 PM
          I totally agree, I don't care how long it's been that ain't right and they'll know it. The minute you pointed out to them it's not like you took them out and turn them around and put them backwards or even ran the motor..
          • Agree Agree x 1
          • 4spdragtop
            4spdragtop Well-Known Member
            27,898
            7702
            Aug 28, 2009
            Wasting time here
            Local Time:
            2:47 PM
            If he made that mistake, I would be worried about the rest. Rods are oriented drivers side vs pass side.
            I would at least try to get them to fix.
            • Agree Agree x 2
            • SGBARRACUDA
              15,539
              4789
              Dec 7, 2006
              Local Time:
              3:47 PM
              If you swap 1 with 3, 5 with 7, 3 with 1, 7 with 5. The fly cuts will be right. Same with the even numbers.
              • Like Like x 1
              • Greg A Sutphin
                48
                30
                Feb 10, 2019
                North Carolina
                Local Time:
                3:47 PM
                The rods are on the journals they came off of. That's when I noticed it. I was moving to a new house a couple days after I got them back and went with it so I wouldn't have parts laying everywhere after I moved. I was also driving a truck so I was not home to do anything about them. Now years after, i don't have a Chrysler body to drop the engine in so I am trying to sell the engine, I am hoping they can be flipped on the rods they are on to make them right. I don't know if KB pistons have a certain direction they need ot be installed.
              • Greg A Sutphin
                48
                30
                Feb 10, 2019
                North Carolina
                Local Time:
                3:47 PM
                I will load it up and take it up there. They were supposed to be good. The fella must have been smoking crack that day.
                • Agree Agree x 2
                • Greg A Sutphin
                  48
                  30
                  Feb 10, 2019
                  North Carolina
                  Local Time:
                  3:47 PM
                  I will have to measure the holes to make sure they aren't too far out of spec wouldn't I?
                • Greg A Sutphin
                  48
                  30
                  Feb 10, 2019
                  North Carolina
                  Local Time:
                  3:47 PM
                  The rods are on the journals they came off of it's just he put the pistons on the rods upside down.
                • j par
                  19,884
                  9788
                  Jul 2, 2014
                  Portland Oregon
                  Local Time:
                  12:47 PM
                  I know my engine builder four years later now can just look up my name and get my build and re go over everything that was done at any time. Just called him the other day talking about some aluminum heads and he looked it up and told me everything that was done to it originally.
                • Greg A Sutphin
                  48
                  30
                  Feb 10, 2019
                  North Carolina
                  Local Time:
                  3:47 PM
                  I will call them tomorrow. It's been a good while. Like someone said here earlier, it's not like I took them off and did it myself or ran the engine. Isn't the even # cylinders on the passenger side of the block on a Chrysler? Hell, I might have screwed up if that's the case.
                • SGBARRACUDA
                  15,539
                  4789
                  Dec 7, 2006
                  Local Time:
                  3:47 PM
                  Then you should have the pistons swapped to the correct rod arrangement. It is possible to swap holes with rod/piston assemblies on the same side. But why? you paid to have it done right.
                  • Agree Agree x 1
                  • Greg A Sutphin
                    48
                    30
                    Feb 10, 2019
                    North Carolina
                    Local Time:
                    3:47 PM
                    True, It does need to be made right and if they break one, they pay for it.
                    • Agree Agree x 1
                    • Rmoore
                      260
                      119
                      Nov 14, 2018
                      Local Time:
                      2:47 PM
                      Yes it does matter how the pistons and rods are installed. On all 4 corners cylinders the small valve relief on each piston in those positions needs to be to the outside because that's where the ex valves are located. The 4 center cylinders the small valve relief needs to go to the inside of the the cylinders thus once again that's where the center ex valves are.
                      • Like Like x 1
                      • SGBARRACUDA
                        15,539
                        4789
                        Dec 7, 2006
                        Local Time:
                        3:47 PM
                        even on passenger side, odd on drivers side.
                        • Thanks! Thanks! x 1
                        • Greg A Sutphin
                          48
                          30
                          Feb 10, 2019
                          North Carolina
                          Local Time:
                          3:47 PM
                          I know the rods but I see he has an arrow drawn on the pistons like they have a certain direction they had to be installed on the rods. He might have thought the odd # cylinders were on the passenger side of the block and the evens #'s on the drivers side.
                        • j par
                          19,884
                          9788
                          Jul 2, 2014
                          Portland Oregon
                          Local Time:
                          12:47 PM
                          °^^I'd say listen to it Roy says. I just got my first big block the other day and I'm still figuring stuff out. But right is right and wrong is wrong and that ain't right ..
                          • Greg A Sutphin
                            48
                            30
                            Feb 10, 2019
                            North Carolina
                            Local Time:
                            3:47 PM
                            That's what I thought, like a Chevy. He must have thought a Dodge was like a Ford. Odds are on the passenger side on them.
                          • krazykuda
                            krazykuda Well-Known Member FABO Gold Member How-To Section Editor
                            50,932
                            15724
                            Aug 20, 2007
                            Orland Park, IL
                            Local Time:
                            2:47 PM
                            See if you changed banks for the pistons if the valve reliefs and squirt hole/anchor slot will be in the proper orientation... If you can't fix it by changing pistons from one bank to the other, then:
                            If the pistons have floating wrist pins, then you can fix it yourself... Just remove the wrist pin clip from one side of the piston and slide the wrist pin out...
                            The arrow on the top of the piston should point to the front of the engine, and the connecting rod squirt hole should point towards the middle of the engine (Towards the opposite cylinder) and the anchor slot on the rod for the bearings should be toward the outside of the engine block...
                            One bank will be the opposite of the other....
                            If the pistons have press fit wrist pins, then you need to take them back to the machine shop and have them fixed as I stated above... ^^^^^
                            • j par
                              19,884
                              9788
                              Jul 2, 2014
                              Portland Oregon
                              Local Time:
                              12:47 PM
                              you know these machine shops hire people and fire people and things like this happen and then when everything looks clean and neat it sometimes doesn't catch their eye. Bad quality control...
                              • Agree Agree x 1
                              • SGBARRACUDA
                                15,539
                                4789
                                Dec 7, 2006
                                Local Time:
                                3:47 PM
                                Fords have a unique number system, most V8's are 1,2,3,4 on the passenger side and 5,6,7,8 on the drivers.
                                • Like Like x 1
