Why didn't someone think of this sooner?
OH MAN!!! YOU HAVE DONE IT WHY IN THEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEe 'ell didn't I think of THAT!!If you unscrew the stem out of them....they also make a nice vent for them stupid *** new gas cans!
Good idea..453 drill bit is all you need next. Or not. 1/2 i think works.If you unscrew the stem out of them....they also make a nice vent for them stupid *** new gas cans!
A regular old plug? Nah....its 2021Why didn't someone think of this sooner?
Thanks. My first "try" with tank vents was to buy a bag of them on egag. I still have them. They are made like the original "snap in" yellow vents EXCEPT they are poorly made and don't "snap." So they are not very positive. I gripped to the seller and got a bunch of grief. Finally got a refund through egag. They are junk. No idea why I have not thrown them outAfter you drill the hole (I use a 1/2" butterfly bit), just run a bendable piece of wire thru it, and out the pour spout. Then run it thru the cap end of the valve stem and put just enough of a kink in the wire at the bottom of the stem to hold it. Pull it back thru the can until it pokes thru the hole you drilled....and pop it in place. Pull your wire out....and you got a vent!
What’s the catch? To simple must be a catch somewhere LOLIf you unscrew the stem out of them....they also make a nice vent for them stupid *** new gas cans!
I can see that. It’s just so simple and so obvious that it’s almost unbelievable LOLNo catch! Newer plastic gas jugs don't have a vent, and they won't pour worth a crap. Just go buy a rubber valve stem, take your valve stem core remover and take the core out. Drill a half inch hole up high....somewhere behind the handle, and then put it in using the instructions in post # 8. When you need to pour gas, all you have to do is unscrew the little black plastic cap off the valve stem, and you have a vent!
