New k member shoping..
vegasanthony
las vegas
So I have a 1973 dart swinger. Original slant 6. No powersteering..
I was wondering about buying a tubular crossmember.
Say Qa1..
Most sites only list them for 1972 dart..will it still fit a 1973?
the QA1 uses the 67-72 engine mounts and motor mounts...
only works with small blocks unless you use some adapters..
I have 3 of them in use.....
Thank you for your quick response
intend on dropping in a 2000 Dodge magnum swap into my 73 so I'll be OK with this tubular front end 1972and my engine swap?
Sorry I just want to clarify before I buy this K member
as long as you use the 72 and earlier mounts and biscuits...
what part of vegas are you in?
They work for big blocks too.
THe Qa1 is a funny deal though.
They use early mounts, later sway bar.
So I've been looking around at my options I'm pretty sure I'm going to go with the qa1 K member on that note can anyone tell me what kind of K member this is I think it's beyond help
