it has some thing to do with regulations,,,,probably driven by C.A.R.B california emmissions basically,,,I know the father of the Tamiya brand passed away recently but I can't see them stopping selling the paint here
I think some plastic can be heated & bent as needed. Try using really hot water. Drop the plastic in it for a bit & try to bend it. Use pieces of the parts sprue to make one also.I've been working on the interior and I searched the internet to find a picture of my original Lakewood three point roll bar. The hemi under glass came with a conventional roll bar which I will try and modify. Can the plastic be heated and bent?
i would think a heat gun would make it bendableI think some plastic can be heated & bent as needed. Try using really hot water. Drop the plastic in it for a bit & try to bend it. Use pieces of the parts sprue to make one also.
Some plastic bends easier than others, but you jumped right in! I think you'll be hooked on fabbing stuff, that's how ya learn. Good job.I probably should have started with one of the kits that didn't require so much fabrication for my first effort![]()
Wire in hollow tubing is a great idea, but I don't think piano wire will hold its shape & want to straighten out. Maybe some electrical wire of the right O.D.?what about hollow tubing with a piece of piano wire inside? just a thought
That's an idea! Have to be solid core not stranded...take the vinyl coating off in spots to paint. leave the rest on to simulate padding? Thanks for the idea! If I can just remember it when I get to that pointWire in hollow tubing is a great idea, but I don't think piano wire will hold its shape & want to straighten out. Maybe some electrical wire of the right O.D.?
Yep, I've even used "stranded" wire to make heater hoses, upper & lower radiator hoses etc. You should see some of the things a friend of mine makes from stuff he has just laying around! I get some good ideas from him too. I just wish I was that creative some times.That's an idea! Have to be solid core not stranded...take the vinyl coating off in spots to paint. leave the rest on to simulate padding? Thanks for the idea! If I can just remember it when I get to that point![]()
More ideas I'll probably forget but that sounds good. I thought I was doing well when you could wire the distributor with thick thread. That and running fuel line from the tank to the carb was about as detailed as I got.Yep, I've even used "stranded" wire to make heater hoses, upper & lower radiator hoses etc. You should see some of the things a friend of mine makes from stuff he has just laying around! I get some good ideas from him too. I just wish I was that creative some times.
Yes, me too. It's good enough for me.sounds like the way I did it but on the cap the wires were just glued down flat
I had to trim that same area, in the same way you did, to fit the engine belts & fan in place. I installed a radiator from parts I saved & trimmed it to fit too. You do have a removable hood on yours right?The roll bar has completely set and I am happy with the way it fits. I got the engine completed, it's a shame that with the closed hood, nobody will ever see it except from the bottom. I had to trim a bit more clearance on the chassis for the fan and pulleys. I mocked up the engine, rear end and driveshaft and got it all fitting. Painting is next up before further assembly. I also have the headers from the hemi under glass to replicate my old fenderwells.
I see. You're using the "HEMI UNDER GLASS" body on the 65 chassis right?The hemi under glass body does not have a removable hood, why would it, the engine is in the back seat.![]()
Think I've seen that car somewhere before...ill be using the hemi under glass to make a model of my prostreet barracuda, all tho my car didnt have the wheel opening cut out, i couldnt bring my self to do it,i wish there was a 66 body that wasnt
