New RCD Bilstein Shocks Sooo Squeaky
Discussion in 'Suspension, Steering and Chassis' started by CaseyW, Nov 9, 2016.
  1. CaseyW
    CaseyW Well-Known Member
    70
    14
    Apr 19, 2012
    California
    Local Time:
    6:21 AM
    Just put new front and rear RCD Bilstein shocks on my 63 Valiant and the car is now sooo squeaky. Lubed the back because they were harder to get on. They squeak. Didn't lube the front and they squeak. Do I have to live with this?
  2. jdsduster
    jdsduster Well-Known Member
    1,072
    105
    Aug 5, 2011
    indiana
    Local Time:
    9:21 AM
    hmmm.mine did not squeek.i wouild try lubing the rubber eye before bolt goes on.they are one of the best shocks ive ever used
    • Thanks! Thanks! x 1
    • Agree Agree x 1
    • MuuMuu101
      MuuMuu101 Well-Known Member
      1,776
      165
      Jul 6, 2012
      SoCal
      View My Photos
      Local Time:
      6:21 AM
      Yes, you should definitely be using a suspension lube/grease on both the front and back bushings and shock mounts before installation. Be sure to clean the shock mounts prior to lubing.
      • Agree Agree x 1
      • dans4door1970
        dans4door1970 Well-Known Member
        160
        34
        Jun 23, 2013
        colorado
        Local Time:
        7:21 AM
        Be sure your nuts are tight enough to squish the rubbers a bit. you may have movement because of being loose. Bilstein in my humble opinion are the very best
        • Agree Agree x 1
        • kiss
          kiss Well-Known Member
          850
          390
          Sep 1, 2008
          San Diego, CA
          Local Time:
          6:21 AM
          You need to remove the rust and burrs on all mating surfaces to the rubber mounts (studs, cup washers, etc). Then you need to use the appropriate grease on said surfaces in good quantity.
          • Like Like x 1
          • Agree Agree x 1
          • jbc426
            jbc426 Well-Known Member
            1,544
            414
            May 30, 2007
            West Coast
            Local Time:
            6:21 AM
            I use synthetic disc brake grease on anything that move spins or rubs in my cars, especially on ALL suspension components and bushings. It lasts for decades, won't wash out and has all kinds of slippery stuff in it. It also wont attack rubber, plastic or any other material.
            • Thanks! Thanks! x 2
            • dans4door1970
              160
              34
              Jun 23, 2013
              colorado
              Local Time:
              7:21 AM
              Good idea
            • CaseyW
              70
              14
              Apr 19, 2012
              California
              Local Time:
              6:21 AM
              I believe the RCD have poly bushings, so they don't really squish down like rubber would. I installed flat washers instead of the cup washers on the rear springs because the cup washers didn't look like they would be the right fit for the shape of the new bushings, and it didn't come with anything. I'll pull everything this weekend and clear surfaces and grease the sh*t out of everything. Thanks for the feedback.
            • dans4door1970
              160
              34
              Jun 23, 2013
              colorado
              Local Time:
              7:21 AM
              I've never heard anyone happy with poly bushings cause they always squeak!!
              • Disagree Disagree x 1
              • jbc426
                1,544
                414
                May 30, 2007
                West Coast
                Local Time:
                6:21 AM
                Mine never do.
                • Agree Agree x 1
                • jbc426
                  1,544
                  414
                  May 30, 2007
                  West Coast
                  Local Time:
                  6:21 AM
                  Don't use regular grease or it will eventually destroy the bushings.
                  • LovetheA's
                    LovetheA's FABO Gold Member FABO Gold Member
                    639
                    76
                    Aug 26, 2010
                    Danbury, CT
                    Local Time:
                    9:21 AM
                    Is the lubricant included in the kit for polyurethane bushings appropriate? Is it synthetic? Because I called PST and they said it was white lithium grease I should use? I'm confused?
                    Carl
                  • PST
                    PST Marketing Manager FABO Vendor
                    758
                    192
                    Apr 22, 2009
                    Montville, NJ
                    Local Time:
                    9:21 AM
                    With poly bushings you can you a lithium grease as it will not break down the compound of the poly.
                    Thanks
                    James
                  • 72bluNblu
                    72bluNblu FABO Gold Member FABO Gold Member
                    8,970
                    2912
                    Nov 28, 2008
                    NorCal
                    Local Time:
                    6:21 AM
                    I love poly bushings, and if kept properly lubricated with the right grease they don’t squeak. Mine don’t, and I run poly bushings everywhere. Well, except where I’ve upgraded to delrin now.
                    Never had an issue with the Bilsteins either. Clean the shock mounts and make sure the bushings are lubricated.
                  • Steve Agrella
                    Steve Agrella FABO Gold Member FABO Gold Member
                    320
                    66
                    May 4, 2018
                    Mission Hills Ca
                    Local Time:
                    6:21 AM
                    Purchased RCD Bilsteins for my Duster, do you guys put dust covers on them or just run them without.
                  • 72bluNblu
                    8,970
                    2912
                    Nov 28, 2008
                    NorCal
                    Local Time:
                    6:21 AM
                    They're designed to be run without, they have a double seal to keep stuff out. If it bugs you there are generic boots available for off road shocks.
                  • Steve Agrella
                    320
                    66
                    May 4, 2018
                    Mission Hills Ca
                    Local Time:
                    6:21 AM
                    I’m good running them without, wasn’t sure, thanks for the reply
