Newbies need help!!!
AbodyNewbie
Active Member
Severn On canada
Hi everyone. Really need to get some guidance on this. We are just getting ready to install new frame rails front an rear and lots of sheet metal. I have this drawing which shows all the measurements the car should be and I want to double and triple check everything.
I know this is a really big ask but could someone show us pictures where each of these measurements are taken from.
My ocd is kicking in and I want to be exact!!!
A real been there done that guy...him and his son are wizards!!!!
who is this oldmanmopar. Seems to be a legend around here!!!
He's one of the go- to- guys on here that would likely know the measurements your looking for. Your in luck as mtrhead is one of our main parts go- to -guys on here. Hopefully someone responds with the info you want. Best of luck.
There should be a few datum points (fixed obvious points to base others off ) most obvious is centerline of chassis. Park on a level concrete garage floor and jack stand the subframes with 4 identical jackstands. Dont trust tires or hanging suspension points.
